Old 03-19-2013, 08:48 PM
N941WR's Avatar
N941WR N941WR is offline
Default How efficiently can you fly?
I was looking over some pictures from a trip I took this past summer and found this:
That works out like this:
141 Nautical miles per hour / 162 Statute miles per hour
At 3.1 GPH...
45.5 Nautical miles per gallon / 52.3 Statute per gallon
Leaving an hour’s reserve, this works out to a range of:
10.6 hours of flight time that will allow me to fly...
1496 Nautical miles / 1720 Statute miles
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-19-2013, 09:01 PM
erikpmort's Avatar
erikpmort erikpmort is offline
Interesting how did you get 3 gallons, when mine reads 3.x gallons at 1800 rpm running up on ground ?
Erik Mortenson
Rans S-20 low and slow
14 build working on wings
Old 03-19-2013, 09:02 PM
erikpmort's Avatar
Furthermore I fly at your settings frequently- 2350 rpm 19 mp around 6-7k and see 6 ish gallons sometimes dip in the fives. I don't have a lop indicator though.
I don't have EI like you I wonder If it's that much better. Wow.
Erik Mortenson
Old 03-19-2013, 09:06 PM
Default Super efficient method
Once in a while I pull the red knob all the way out and fly burning 0.0 GPH for several minutes. Who can beat that?
Old 03-19-2013, 09:12 PM
N941WR's Avatar
^^^PHYSCO^^^
Bill R.
SC86 - Easley, SC
Old 03-19-2013, 09:15 PM
N941WR's Avatar
It could be the fuel flow you are using and how you have the range set up in the SkiView. I don't recall exactly how mine is configured.
With the aircraft moving, you can get higher RPM's at the same power setting then when sitting on the ground and the prop is struggling to move through the air.
Yes, dual electronic ignition is that much better!
Bill R.
SC86 - Easley, SC
Old 03-19-2013, 09:25 PM
jetdriven jetdriven is offline
Thats incredible. Thats TWICE what a Mooney 201 can do, and thats the most efficient certified plane in its class. Amazing.
Byron
1977 Mooney 201
Houston, TX
Old 03-19-2013, 09:39 PM
N941WR's Avatar
Look at it this way, our planes share the same MPG per seat numbers.
Bill R.
SC86 - Easley, SC
Old 03-19-2013, 09:58 PM
Sig600 Sig600 is offline
Those CHT's seem really high for how far back on the power you are. Pretty stellar MPG though!
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 03-19-2013, 10:07 PM
RetiredRacer RetiredRacer is offline
Default Nearly as good
Bill we just got back from a 259 NM trip through Australia's outback. On our last fuel top-up to get home we were quoted a $100 call out fee. I told him what he could do with his avgas as we believed we had enough to get home (with reserve). I have never tried LOP as I want to get the CHT's more even with some playing around with the baffles, so once at altitude I just pulled the throttle back to 100-105 kts IAS (110-115 kts TAS) and was cruising along at 15 LPH (3,9 GPH) (60% ROP)
Bob
0-235 RV9a
(P-Mags and Rotec TBI)
