Old 03-18-2013, 06:34 PM
rvator51's Avatar
rvator51 rvator51 is offline
Default 90 degree fitting in fuel pump
Is it OK to use a 90 degree fitting in the input of the fuel pump? I know they are used in the output side of the fuel pump. My fuel line is comig from the left side of the engine and I could use a shorter hose from my gascolator to the fuel pump if I used a 90 degree fitting.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
Old 03-18-2013, 06:40 PM
roee roee is offline
My engine came that way from Aerosport, so I presume it's ok.
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Old 03-18-2013, 07:32 PM
Rupester Rupester is offline
Mine has one too. Must be OK.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 03-18-2013, 07:36 PM
Larco's Avatar
Larco Larco is offline
Absolutely Tommy.
Old 03-19-2013, 12:02 AM
rvator51's Avatar
Thanks everyone! A 90 degree turn downwards, it is.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
