Garmin Pilot
I am doing the trial period with the Garmin Pilot and using a WiFi only Android tablet. When I turn the WiFi off and I try to zoom in the map it goes blank as if it needs a connection to download the map data. This makes the thing useless for inflight use as there will be no WiFi connection. Even if I had cell data most altitudes would not get a good cell signal.
Is there a way to download the map and chart data so it is available in flight, or is this just a limitation of the trial version. I don't want to buy the subscription unless I can make the maps and charts available inflight.
Thanks for the help, a Google search of this question was not fruitful, my be the way the question was worked.
Cheers
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
