Old 03-16-2013, 03:12 PM
JRV JRV is offline
Default AeroLed and Trim wires
Hello,
I am looking at the wire run for the Electric Elevator trim, and a Aeroled suntail strobe.
Should these wires be kept separate in the wire run/conduit down the fuselage, or is this not an issue with the Led strobes?
2015 Donation Paid
Old 03-16-2013, 05:04 PM
rleffler's Avatar
rleffler rleffler is online now
Originally Posted by JRV View Post
Hello,
Not an issue if you wire exactly like Aeroleds specifies.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 03-16-2013, 05:38 PM
JRV JRV is offline
Thanks. Much easier to just have one run.
2015 Donation Paid
Old 03-16-2013, 06:12 PM
Dean_aeroleds's Avatar
Dean_aeroleds Dean_aeroleds is offline
Coupled noise signals are very low amplitude, and typically only show up in systems that have amplifiers (radios, audio panels) that can boost the noise up to a level that is detectable. A trim servo uses high power currents and cannot respond to weak low amplitude noise, so this is not an issue.
Dean Wilkinson
CTO, AeroLEDs LLC
Hello,
Old 03-19-2013, 12:27 AM
JRV JRV is offline
Thanks Dean.
2015 Donation Paid
