Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
Old 03-15-2013, 02:09 PM
Weasel's Avatar
Weasel Weasel is offline
Default Lightspeed Sparkplug Wear
This is a Denso W27ESR-U.
Has 250hr Tach time and has been running LOP most of its life.
Is this what I should expect to see?
Note: center electrode is showing wear. Looks rounded off. All 6 plugs look the same.
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1600hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 03-15-2013, 02:51 PM
gasman gasman is offline
Yes, replace them. The wear looks normal for the time.That gap looks a bit large. Keep the gap within specs. Set at minimum and readjust when they hit max gap. A gap out of max will strain the coils and cause coil failure.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 03-15-2013, 03:22 PM
Radomir's Avatar
Radomir Radomir is offline
Normal.. as mentioned.. put iridium plugs as they don't wear nowhere near as much..
Radomir
RV-7A sold
Old 03-15-2013, 05:36 PM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default Yup
I am at 260 hrs and just did my plugs, exactly like that. For $2.50 each I will just replace every 200 hours or so. Wish the mag plugs where that cheap.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 03-15-2013, 07:45 PM
Not any more for Denso..... You might want to try NGK..... Look good so far.
Old 03-15-2013, 08:41 PM
Weasel's Avatar
What P/N NGK is used? do you just use the standard NGK or the V-power NGK or some other model?
Weasel
RV-4 715hr Sold
RV-8 700+hrs
SERFI AWARDS
Old 03-15-2013, 08:47 PM
Walt's Avatar
Walt Walt is offline
BR8ES (standard) or BR8EIX (iridium)
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 03-15-2013, 11:11 PM
bhester's Avatar
bhester bhester is offline
Thumbs up Solid cap
Get the solid cap plugs not the screw on cap. If I remember correctly they have a different number on the box for each or they just say solid cap or screw on cap they come both ways. I use the BR8ES and change them every year, they are cheap or should I say inexpensive.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 03-16-2013, 01:47 AM
Correct.... And a 9ES is cooler.
