03-13-2013, 07:41 PM
Bell tail wheel
How much difference will 7 more ounces make by adding the Bell fork?
My soon to be new to me -6 has a Van's tail wheel with fairing. Doug Bell said they weighed both with the bolts but less the wheel and the Bell was 7 ounces more. I would have to weigh the fairing and subtract that amount from the 7 ounces to see what the exact difference would be for my plane.
Just wonder how much effect a few ounces back there is going to have on handling? I have read all the posts I could find and ereyone that has made this change seemed to really like it.
03-13-2013, 07:45 PM
been here awhile
So what are you asking?
Enjoy your new plane!
03-13-2013, 07:51 PM
It isn't so much about the weight of the TW fork but allowing the TW to ride up and over things rather than getting hooked and damaging the plane.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
03-13-2013, 07:53 PM
Tail wheel fork
Just curious if it would make the tail feel more heavy when slow or if it would make the elevator feel more sensitive.
03-13-2013, 07:54 PM
I doubt you would even notice it.
Not a single person on this forum has talked about feeling the extra weight back there.
I started with the Bell TW fork and never flew with the Van's fork.
You can always buy a DJM tail wheel, which is lighter than stock and has sealed bearings. That will help balance things out a little bit.
Bill R.
SC86 - Easley, SC
03-13-2013, 09:39 PM
tail wheel weight
If you are worried get one of Dayton Murdocks light tail wheels. It's alot lighter than the original.
Horse Power is good, more is better and
Too Much is Just Right
RV 8 Super charged Barrett IO-390
Dues paid 2020
Dan "Nordo" West
03-14-2013, 05:36 AM
DJM = Dayton J. Murdock
Dayton is the same guy who makes the throttle quadrants and one smoken' fast RV-4.
Here is a picture of mine, after 250 hours. I measured the wear for Dayton, that's why the tape measure is in the picture. (It has warn an 1/8 of an inch, flying off of pavement.)
Notice the lightening slots and sealed bearings. Every annual I simply clean it and put it back on.
Bill R.
SC86 - Easley, SC
03-14-2013, 08:00 AM
You'll never notice the weight difference in performance or handling.
Rob Prior
03-14-2013, 08:50 AM
I ran the weight and balance on this once - the movement in CG is very small for a few ounces on the tail. Don't recall the exact numbers, but it equated to a few pounds (maybe 4) in aft baggage capacity.
Another way to say it is changes of ounces at the tail wheel are not an effective or practical way to move CG. It takes pounds on the nose (changes in props or moving the engine with different mounts) to effect significant changes in CG.
The small effect on CG of the OP's tail wheel change will not be dramatically noticed in flight characteristics or utility.
Gary Reed
RV-6 IO-360
WW 200 RV now an Al Hartzell for improved CG
03-14-2013, 11:14 AM
There are other alternatives for tailwheel forks, including our retrofit fork. Ours weighs virtually the same as a Van's fork (within an ounce). Our Screaming Eagle fork gives better clearance and superior handling. It is a 5 minute job to install it, excluding painting it to match your colors.
Screaming Eagle retrofit fork for Van's RV type tailwheels
Our fork will also accept a tailwheel pant, if desired, and still retain complete full swiveling capabilities.
Please check out our other RV accessories at the URL below.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
