Old 03-13-2013, 08:21 AM
gtmule gtmule is offline
Default where to find 430 connector shells (and other stuff)
My plastic tackle box with my GNS430 and GTX327 connector shells, a bunch of wire terminals, switches, and hardware was (for some reason) stolen out of my car recently. Anybody know what the best place to replace the connector shells (I think I still have enough pins left to finish) is? I shouldn't need pins, bodies, or anyhting else, just all the shells for a 430 and a 327....
I guess I'll RE order my switches, terminals, etc now.....ugh.
Macon, GA (KMCN)
RV-7, Niner Fife Victor
Old 03-13-2013, 08:38 AM
rleffler's Avatar
rleffler rleffler is offline
Sorry to hear about the theft. What a bummer!
I would talk with the vendor that you purchased the gear from. They should be able to order the connector kits for you. Most may even have enough product in stock to ship immediately.
If you bought used, I would recommend either SteinAir or Aerotronics.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 03-13-2013, 08:46 AM
kinger's Avatar
kinger kinger is offline
When I need to order these last summer I purchased them from..
http://www.approachfaststack.com
I am sure they can help you or even Stein Air.
http://www.steinair.com
James King
RV-7
919
Old 03-13-2013, 09:02 AM
bkthomps bkthomps is offline
i have a GTX330 tray/shell I believe that is no longer going to be used for my project, make me an offer if it will work for you
Old 03-13-2013, 09:05 AM
Wayne Gillispie Wayne Gillispie is offline
Check with Stark Avionics in your area.
http://www.starkavionics.com/
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 03-13-2013, 10:07 AM
larrynew's Avatar
larrynew larrynew is offline
Default Mouser
I got the 25 pin cinch backshells from Mouser, $3.59 each. They also have the bigger ones in-stock. I believe the 50 shell size is what fits the 78 pin. I'd double check the dimensions first, though. Their catalog page is below and the item is figure "G", third column in the description.
http://www.mouser.com/catalog/catalogusd/645/1451.pdf
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 03-13-2013, 10:28 AM
You're the man! I'll measure the parts up tonight, I assume you mean the high density 78 pin or whatever looks like the 50 pin regular density shown there?
Macon, GA (KMCN)
Old 03-13-2013, 11:00 AM
larrynew's Avatar
Yes, the 50 pin regular density d-sub is the same size as the 78 pin high density d-sub that we use on the 430W so shell size "50" is what you want. Also, I believe the 25 pin regular is the same size as the 44 pin high density so they both take shell size "25".
Hope that helps,
Added info about backshell connectors for the Garmin GNS 430W and other older Garmin products. It took many hours to find a source and understand what was needed so I wanted to make it easier for others that follow.
Start by opening this link to the Mouser catalog page. The 430W takes 3 of the "Deep Straight Clamp Junction Shells" shown as picture G. The two smaller d-subs are a 25 pin standard density and a 44 pin high density which take the same size shell and the larger one is a 78 pin high density. You will need two of Mouser part # 538-DB-24659-32 (shell size "B" or "25") and one of part # 538-DD-24661-34 (shell size "D" or "50").
To decode the shell size, look at the second column on the Mouser catalog page at the Cinch Part Numbers. The second letter of the part number is the shell size. E=9 pin standard which is the same size as the 15 pin high density, A=15/26, B=25/44, C=37/62 and D=50/78.
Larry New
Last edited by larrynew : 03-14-2013 at 09:45 AM. Reason: Added Cinch Backshell Info
Old 03-13-2013, 11:02 AM
Hope that helps,
Sehr gut! I intend to visit the hill country when I get flying again...
Macon, GA (KMCN)
Old 03-13-2013, 11:14 AM
larrynew's Avatar
Let me know. Wurstfest is a great time to visit.
Larry New
