03-11-2013, 06:22 PM
filling holes in sheet metal?
Any tips or ideas on how to fill holes in sheet metal? Like the holes left behind after moving an antenna or pitot tube? This is a finished and plane.
Fiberglass? Sheet metal patch riveted on? Or maybe some sheet metal and proseal?
For now it just has a patch of aluminum tape. Works but not pretty.
Michael Delpier
RV6A -O-320, fixed pitch, GRT Sport, 496
RV-10 - working on finish kit
Houston
03-11-2013, 06:32 PM
if you're dealing with round holes, the flush pop in plugs fit tight and can be epoxied in place.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
03-11-2013, 06:54 PM
Cap it
As Reilly mentioned, you can get one of those pop in caps. Drill as appropriate. I recommend Click Bond as the adhesive. It won't be going anywhere.
THEN, if anybody asks just tell them about the mandatory service bulletin requiring the mod
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
03-11-2013, 07:12 PM
Stainless screw/nut.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
03-11-2013, 10:53 PM
If you have an odd hole like a streamlined pitot hole, you could flush patch it. Use a piece of Al the same thickness as the skin and cut/file a plug that fits the hole exactly. Rivet this to a larger patch that will fit inside. You could probably get 4 rivets in a pitot shaped hole patch. Then you can pick up the existing rivet holes in the skin and add as many more as you need to lock your patch in flush. Afterwards it can be sanded and have the seam filled to be invisible.
Actual repeat offender.
03-11-2013, 11:25 PM
Oops buttons..
*sigh* I have a couple of these and my plane is not yet flying!
go to
http://www.mcmaster.com
and do a search on
sheet metal plug
metal one are at the bottom.
cc
David Boeshaar
RV-9A - N18TD (reserved) - Fuselage.
"My greatest fear: What if the hokey pokey really IS what its all about?"
TDAircraft.com
-July-
03-12-2013, 05:13 AM
go to
and do a search on
sheet metal plug
cc
Me too, just added two extra holes for no apparent reason, ok stupidly was the reason..
03-12-2013, 09:38 AM
When properly done as described it looks professional and appropriate, even when the joint is not filled. A patch is a story and adds to the character of the aircraft. Sadly I have none on my machine, yet.....
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
03-12-2013, 11:37 AM
go to
and do a search on
sheet metal plug
cc
Home/Aviation Depot carries a number of these in metal and various sizes as well for local sourcing.
CharlieWaffles - But you can call me " Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
03-12-2013, 02:06 PM
Bond a piece of aluminum on the inside, then fill the hole on the outside with some JB weld. Put some packing tape over it (not the sticky side) to let it dry smooth. Then sand it flush and paint.
