Old 03-07-2013, 10:46 AM
SHIPCHIEF SHIPCHIEF is offline
Default Controls Free & Clear
Yesterday, While working on completing my RV-8, I reviewed my primary flight controls, and installed the aileron travel stops. I was checking control friction, and noticed some in 'pitch'. So I went back to the elevator and started poking around. finally, I pushed it all the way down to the stop. When I pulled it back up, IT STUCK! But it still moved in a springy way. I couldn't easily find the problem because everything could move a little bit.
Finally, I found it in the right elevator. The skin overlap (pop riveted together at the front) had caught on the lower spar bar of the horizontal stab.
This assembly has been together for several years, and I'm getting pretty close to the Airworthiness Inspection. Needless to say, this whole thing is going to be taken apart and the plans reviewed etc.
So my comment to everyone: Keep a close eye on your primary flight controls!
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 03-07-2013, 10:54 AM
Brantel's Avatar
Brantel Brantel is offline
Good catch.
The RV control system is so free of slop and binding that if there is any and I mean anything that you can notice, you need to find it and correct the issue.
The exception is when you have autopilot servos attached, the ones that use stepper motors do produce a slight feedback into the system even when turned off. This effect is very slight however...
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 03-07-2013, 03:48 PM
bird's Avatar
bird bird is offline
Yes you might need to back out the rod end bearings a bit thus moving the elevator away from the horizontal stab a bit.
Bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 03-07-2013, 05:03 PM
Bird;
Yes, I may need to re-roll the seam and re-rivet, while I'm checking that rod end bearing setting dimension.
Scott Emery
2019
Old 03-07-2013, 06:05 PM
Toobuilder's Avatar
Just recently noticed a little "snag" in the rudder as it passed through faired. Short investigation revealed the screws holding the lead counterweight were backing out and catching the skin. Didn't expect that one!
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 04-03-2013, 10:44 AM
wrongway john wrongway john is offline
Tell me about it! I was probably still a hair's width or two from catching, but make it a part of the pre-flight inspection from here on out.
Old 04-04-2013, 07:46 AM
Jimd Jimd is offline
Default Free and CORRECT
I make a point of this with all my students, because some of the rental aircraft we fly have a checklist that states it as the title of the article.
You should be thinking about TWO different elements during this check.
Freedom of movement as is the case in this thread.
The second element is CORRECT direction of movement.
Please don't use FREE and CLEAR, change it to FREE and CORRECT.
Jim
RV-6
RV-10 tail kit 50%
(When do I get to measure something?)
"Flying north of the Arctic Circle and back - several thousand dollars,
Doing it in an RV you built yourself - PRICELESS!"
