Old 08-02-2006, 08:50 PM
N395V's Avatar
N395V N395V is offline
Default Pressure recovery Wheel Pants
Catchy name but I am confused as to what it means and the physics behind it.
Can someone explain (in small words) exaxctly what pressure recovery means relative to wheel pants.
Milt Concannon
Old 08-03-2006, 08:36 AM
DGlaeser DGlaeser is offline
Default pressure recovery
Fundamentally, it means the shape is designed to minimize flow separation on the downstream side of the fairing. Minimum form drag occurs if laminar (non-separated) flow can be maintained along the entire surface of any body moving though the air.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 08-03-2006, 08:54 AM
TShort TShort is offline
What happened to the small words
T.
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
Old 08-03-2006, 09:36 AM
Ironflight's Avatar
VAF Moderator / Line Boy
T.
It is shaped so that the air sticks to it better!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-03-2006, 09:39 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
less drag.
Mike
Old 08-03-2006, 10:55 AM
LOL - That was sorta tongue in cheek but thanks for the replies - makes more sense now to this non-engineer !!
My understanding is that these are smaller and tighter fitting - any issues with grass or unimproved strips?
T.
Thomas Short
Old 08-03-2006, 11:20 AM
Dgamble's Avatar
Dgamble Dgamble is offline
T.
I just replaced my old-style RV-6 pants with the newer PR pants, and the new ones are most assuredly not smaller! I was actually surprised at the improved performance because the new ones look so much larger than the old ones.
There's a side-by-side comparison here:
http://n466pg.blogspot.com/2006/06/t...-my-pants.html
Tight fit is up to you. I trimmed mine such that I don't have to worry about tire rubbing if the tire pressure is a little low. I have heard, though, that the newer ones can collect grass and stuff back behind the wheel. I haven't had that happen, but I haven't been flying with the new ones very often yet.
Dave Gamble
Grove City, OH
RV-6 N466PG Purchased already flying - SOLD!
The Book: The PapaGolf Chronicles
Built RV-12
http://www.schmetterlingaviation.com
The Book: Being written.
The above web blogs and any links provided thereto are not instructional or advisory in nature. They merely seek to share my experiences in building and flying Van's RV airplanes.
Old 08-03-2006, 11:45 AM
skelrad skelrad is offline
There is actually a noticeable difference in performance between the two styles?
Old 08-03-2006, 12:45 PM
Dgamble's Avatar
They say there is, but my only real measurement I have is between no pants and PR pants. The old pants got a little, uh, worn during my TW transition, so I've left them on the work bench for quite awhile. The difference between no pants and PR pants has been unscientifically measured as 9 knots on a 150hp RV-6.
Dave Gamble
Grove City, OH
Built RV-12
Old 08-04-2006, 03:01 AM
rickmellor rickmellor is offline
Default History of these things
I'm trying to remember... did the PR wheelpants start out as some team rocket option and then Van's picked them up?
RV7A (aborted in 2007 )
Brooklyn, NY
