Old 08-02-2006, 07:24 PM
briand's Avatar
briand briand is offline
Default The 2 LE Fuel Tank Rivets by the Attach Angle
What do you guys do to make these 2 rivets fit/go in? I found that they hit the angle.
Old 08-02-2006, 07:37 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
I don't think I'm any help here, but I think you were supposed to rivet the inboard rib to the skin before attaching the angle. I know some people have tried to do it the other way, and I thought about doing that but couldn't come up with a good way to buck those couple of rivets. Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 08-02-2006, 08:01 PM
RV8RIVETER's Avatar
RV8RIVETER RV8RIVETER is offline
Default rivet first
You have to rivet the rib in first. Then you can make pretty "half moon" notches, in the front of the angle, where the rivet shop heads are so that it will fit. Just remember to keep the notches smooth with no sharp corners.
Have fun with the black goo!
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
