  #21
Old 11-24-2013, 08:56 AM
Daniel S. Daniel S. is offline
Default RV 7 aileron stop
Hey all-
I just wanted to add to the info here. I initially bought the 1/2" X .194 X 1/2" nylon spacers from Lowes. I trimmed them down to the proper length & installed them. Presto!!! I had 31 degrees up travel... 1 degree less than max travel for the -7. I just ordered the same spacers but in aluminum from aluminumspacers.com for final assemble down the road. here is the link.
http://www.aluminiumspacers.com/oute...s50-10-32.html
DANIEL S.
RV7-A (528KS)
-Empannage Done.
-Electrical System Planning / Schematic Done.
-Wing Kit Delivered 09/13/12.
-Wings 95% Done Flaps & Electrical to go.
-Have got to order the fuse soon!!!!.
[/font]http://www.mykitlog.com/dschoning/
"This is a first-time event, and we're looking forward to it"... Chuck Yeager
Old 11-10-2014, 06:20 PM
xblueh2o xblueh2o is offline
Slight thread revival.
I was working on putting my wings away before going whole hog at the fuselage when I realized I never completed this one mod.
For those who have done the mod and are now completed and flying, what size OD on the rod did you end up using to get the correct throw for an 8? Also, did you drill the rod to 3/16" for just the bolt or 5/16" for the spacer?
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 04-24-2017, 06:32 PM
Pman Pman is offline
Default 5/8" O.D.
I used a 5/8" O.D. spacer on my RV8, it worked perfectly:
Both ailerons up travel = 30 degrees
Both ailerons down travel = 15.5 degrees
Measured with a Digital level.
Hope this may help someone------
Mike p
