  #11
Old 03-06-2013, 12:11 AM
bruceh's Avatar
bruceh bruceh is offline
I have both the delrin stops and the tiny angle stops as the plans call out. Sort of a belt and suspenders approach. They both bottom out at the exact same place, so the 7/8" dimensions are correct for the RV-9 wing.
Here is a photo showing both stops hitting the limit.
The wings have been on the fuselage, and all of the preliminary rigging has been done. If ever the delrin should fail, the other stop will be there.
Bruce Hill
2020 VAF donator
Old 03-07-2013, 09:30 AM
SHIPCHIEF SHIPCHIEF is offline
I followed thru on this topic; and got a 4 pack of 3/4" dia. wheels @ LOWES aerospace. (and a 'hit & run' dent in the side of my pickup truck)
The wheels have roller bearing & threaded axles, so I thru drilled .187 and installed them (plus a washer) in place of the spacer.
28 degrees of up travel is where they stop the aileron. That's about mid way between min and max travel.
This time, I had a magnet on one of those telescoping handles. It seems like I drop the washers and nuts at least a dozen times, so that magnet really sped up the process of picking up the bits and trying again.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 03-07-2013, 09:45 AM
Brantel's Avatar
Brantel Brantel is offline
Washer wrenches are an airplane builders best friend!
Get em from Avery's:
These things are priceless in a few areas like attaching the control surfaces and the control stick weldment/assembly!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 03-07-2013, 11:44 AM
DanBaier's Avatar
DanBaier DanBaier is offline
...a 4 pack of 3/4" dia. wheels ... The wheels have roller bearing & threaded axles...
That wasn't what I used and referred to earlier. In my situation there were no roller bearings etc.
The package label is
You can get them in various lengths - the 1" is
These are 1/2" diameter not 7/8". I don't have the final measurements handy, but after installing these, the aileron travel fell within the Van's guidelines (RV-7). Price for this pkg was $0.92.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 03-07-2013, 03:08 PM
rv8ch's Avatar
rv8ch rv8ch is online now
Default 0.5" worked for me
Here's how I did it:
http://www.rv8.ch/aileron-stops/
Back in the old days we had to buy this stuff from ACS!
Mickey Coggins
http://rv8.ch
"Hello, world!"
Last edited by rv8ch : 04-24-2017 at 11:22 PM. Reason: updated URL for new website
Old 03-07-2013, 05:53 PM
Rhino889's Avatar
Rhino889 Rhino889 is offline
Got me within 1 degree of max travel.
Thanks for the help
VAF DUES 7/13, 12/13, 03/14
Founder/Director
www.Aircraftwraps.com
This is my personal account and does not reflect the official communications of Aircraftwraps.com. We have retained a username for such correspondence. I post about formation, eating, aerobatics and pilot stuff .
Old 03-08-2013, 09:05 AM
Stewie Stewie is offline
Cool idea! I mostly keep an eye on the -3/-4 forums, but I obviously need to expand my perusing.
Eric Stewart
=VAF= dues paid 2016
facebook.com/TheSR1Project
Old 03-08-2013, 09:51 AM
bullojm1's Avatar
bullojm1 bullojm1 is offline
Originally Posted by longranger View Post
I was in Mike Bullock's build log (see Van's builder web site list) looking for something else, and ran across his aileron stop page. He used 3/4" nylon. I have no idea how it's held up.
I used two nylon spacers from Home Depot in order to achieve a 3/4" OD aileron stop:
After over 100 hours they have held up just fine. Full write up on the stops are here: http://www.rvplane.com/?categoryid=4&dayid=556
Mike Bullock
RV-7, Flying!
EAA Technical Counselor
Old 05-05-2013, 12:00 PM
o2flymy6 o2flymy6 is offline
Default Living in the sticks
This is the point in my build and I would love to get a set of these 7/8" stops from Lowe's but live in "the sticks". Anybody near a Lowe's that can help-a-fella out and I cover the expenses and a beer for your trouble?
Jim A
RV-9 - 90% done 90% to go...still
Old 05-05-2013, 02:40 PM
rzbill's Avatar
rzbill rzbill is offline
AMEN.. It was HARD to peel out the cash because they are a bit pricey but that event is long gone history. I'll still be clutching them in my clammy dead hands when I pass. They are GREAT.
Bill Pendergrass
ME/AE '82
