03-04-2013, 06:15 PM
Pop Rivets
I purchased the complete RV tool kit from Avery so I could practice some riveting skills before my kit arrives. In the kit they send a Stanley MR77 pop riveter. The spent shaft from the first rivet came our the top relatively easily. The spent shaft from the second rivet could only be removed after I disassembled the shaft of the rivet gun. Same with the third rivet. On all the videos I have watched, no one has struggled as I have. I purchased the rivets from Menards to practice with. The package for this rivet gun from Avery says nothing about aviation. I have minimal experience with a pop rivet gun, however the cheap rivet gun I purchased decades ago works well for the project I am practicing on.
I assume I am doing something wrong, because I cannot believe spending over 2 grand for this tool kit, in which is this Stanley pop riveter, would yield me an inferior tool. What do you suggest?
Paid my 2013 dues. Dennis
03-04-2013, 06:40 PM
I had the same problem with my Stanley puller. I solved it by buying a POP brand puller. This puller has the added advantage of being able to get into tight spaces without grinding down the nose. This was most notable when attaching z-brackets to fuel tanks, and most recently when attaching the thick reinforcement plate to the inboard end of the flap spar and inboard rib. The only reason I haven't thrown my Stanley puller away is that it's hard for me throw anything away...
RV-7 TU 904KM (reserved)
Construction Log
03-04-2013, 06:59 PM
On my NAPA puller I tip the gun over and squeeze and release the handle and it falls out. Might have to clunk it against something once and a while.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
03-04-2013, 07:07 PM
I think I could drop a three pound sledge hammer on it, while tipped upside down, and the rivet shank would not come out. I have to dismantle the gun each time.
Dennis
03-04-2013, 07:34 PM
Any bend in the spent shaft?
Any bend while pulling it would cause a hang up. When you disassemble, is the spent nail straight? Check the two cone halves for a spur on either inside. Give them a little scotch bright rub, squirt a little lube on it and then try to loosen the screw in the back a turn. Mine usually hang up if its a cherry rivet and I use a nail guide that's too close to exact size. Change out the round guide to the next larger one. One or more of those may do it.
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2020
03-04-2013, 07:45 PM
What does the screw that I can tighten or loosen do?
Dennis
03-04-2013, 09:06 PM
Harbor Freight
I bought a pneumatic one from Harbor Freight. Works great and now I only use the hand-squeeze one in very tight spots. Heck, they were so cheap, I bought a couple of them for my fellow builder friends as gifts. They love them too, and hardly use their hand-actuated pop riveters anymore. My $0.02.
03-04-2013, 09:11 PM
The screw on top of the head tightens or loosens the jaws, should be able to adjust so that it releases t he spent shaft. I have a Stanley and used it for my complete build, it works fine and I like the swivel head too.
Bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
03-04-2013, 10:37 PM
I have that happen a lot. If I use the die in the pop rivet that is too close to the size of the rivet stem it gets stuck. So I tend to use the next size up and that prevents them from getting stuck.
CharlieWaffles - But you can call me " Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
03-04-2013, 11:06 PM
Talk
To someone at Avery - they won't be happy until you are happy - good people. Give them a call and see what they say.
Building finally
