Old 03-04-2013, 03:26 PM
ao.frog ao.frog is offline
Default Tip: An easier way to install the control sticks in a RV-7
Hi.
This mod is probably shown before here in the forum, but it didn't show up in search, and I haven't seen it mentioned in a while.
We did this mod today so I took a few pics and wanted to share them.
I got the idea from my first -7, which I bought partly completed from a US-builder. This builder had done this mod on the kit I bought from him, and I liked it alot, so I copied it on the -7 I'm building now.
The thing is that on the side-by-side RV's, it can be difficult to install all the hardware in the lower part of the control-stick assembly. It's much easier to install the hardware on the workbench and then put the stick-assy in place in one piece.
The kit comes with two seat rib access plates, F-716B, DWG 22, but if you make another two access ribs, the stick assy goes into place in one piece.
Here's how it looks with all the access ribs "closed":
And here they are all open:
As you can see, now the stick assy can be put into place in one piece.
The only thing you have to do, is to make two of these, the F-716B:
Then cut out a portion of the seat rib, shown on DWG 22, rivet that portion together with the parts you just made, and install.
It's easy to do because you just copy the access plates which already are there, and even the holes you need to use are prepunched.
Ofcourse there is some hardware you have to install after the stick-assy are in place; the elevator push rod connection for example, but at least this method makes the stick install task alittle bit easier.
I'd think this metod can be used on other side-by-side RV's too?
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 03-04-2013, 03:53 PM
gasman gasman is online now
You might want to check with Van's on this. They might like more that one attach point on each end.
VAF #897 Warren Moretti
2021 =VAF= Dues PAID
Old 03-04-2013, 04:04 PM
randyintejas's Avatar
randyintejas randyintejas is offline
Good highlight. I got this from Chad?s build site and did the same mod sometime back.
http://chadandbrittne.com/RV-7.htm
He has an excellent build site and many thanks for leaving it up Chad!
RV 7
391RK Reserved
IO360 9:5:1 AFP
Slow Build
Last 90%
Tyler, Texas
Old 03-04-2013, 10:16 PM
Default I have...
..... checked with Vans, and here's Gus's reply:
Alf,
Looks OK to me - all you've done is add the two split ribs shown on dwg 22
to two more (that's a lot of 2s). Since it's OK on the inboard ribs, I don't see
a problem with doing it on the others. Not sure you gain much, the easier
stick install is offset by the extra work on the ribs....
Gus
Old 03-05-2013, 02:27 PM
Rupester Rupester is offline
Default This is a better approach ...
While there's certainly work involved in opening the additional two ribs, that's easier than putting in those teeny AN3 "pivot washers" after the control assembly is dropped in place. The ones toward the bottom were an incredible pain to get install. There were a lot of bad words uttered in my garage during that part of the process.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
