Old 03-04-2013, 01:12 PM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
Default Dynon Display Service Bulletin - Rev B
Dynon Avionics released a Revision B of the SkyView Display Circuit Board Replacement Technical Service Bulletin on March 4, 2013. This Revision B supersedes and replaces an earlier version of this bulletin that was originally released on Feb. 11, 2013.
The original bulletin specified a SkyView-based on-screen detection method to determine whether or not a display was affected. However, displays that were thought to be unaffected based on the on-screen detection method may actually be affected by this bulletin.
Therefore, ALL SkyView displays, whether or not they were already checked against the original service bulletin on this topic, must be re-checked using the updated instructions that are available at SkyView Display Circuit Board Replacement - Revision B.
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 03-06-2013, 12:01 AM
KRviator's Avatar
KRviator KRviator is offline
Upgraded mine to 5.1 today and checked it. All good.
Probably a good thing too, shipping to and from Australia costs a mint. And Customs would probably try to tax me again when it comes back into the country!
Just a thought for the good folk at Dynon... If it is the MAC Address that dictates the fault status, is there the possibility of listing a range of MAC Addresses that cover the potential fault, so guys can avoid going from home to plane (to check the numbers) to home (to verify the address) to plane (to pull the screen) to home to post office?
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 03-06-2013, 09:39 AM
DFlyer DFlyer is offline
Rob, The best thing to do in that situation would be to just call us. If it is morning your time, then our tech guys will be here and will be happy to check your MAC address.
-Robert
Dynon Avionics
