Old 03-02-2013, 05:52 PM
Rupester Rupester is offline
Default Got my Repairman Certificate ...
... and they sent me a nifty plastic wallet card that looks just like my PPL. Is there any reason I would have to carry the Repairman Certificate on my person? I already have plenty of cards in my wallet .... I don't need any more in there. Couldn't i just put the card in my aircrafft file, from which I could retrieve it if someone ever asked for it?
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 03-02-2013, 05:58 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Put it in the sleeve with Reg and Cert in the plane... it will always be with you when you're working on the plane.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 03-02-2013, 06:08 PM
gasman gasman is offline
Keep it with your aircraft maintenance log books. You don't need to have it with you for any maintenance procedures.
The only time you will need it is when you sign off your inspection and you need the number from it. And also, when the FAA is looking at your maintenance log books.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 03-02-2013, 06:09 PM
Or keep it with the aircraft logbooks. You only need it when you sign off the condition inspection.
But I like to show it off. Of my 3 similar looking plastic cards (commercial; cfii; repairman) I'm most proud of the Repairman certificate.
Old 03-03-2013, 09:59 AM
LynnHall's Avatar
LynnHall LynnHall is offline
Default Repairman
Congratulations on receiving your repairman. When I got mine it felt like a lifetime achievement award. They have a new format for the certificate if you are interested. (Charles Taylor).
http://www.faa.gov/licenses_certific...Charles_taylor
Lynn Hall
554LH rv-9a (flying)
http://www.youtube.com/user/554LH?feature=guide[/url]
Old 03-04-2013, 09:25 AM
I kinduv like the idea of keeping it with my logbooks. Seems like I have enough 'stuf' to carry in the plane ... between tool kit, spare tubes, gust locks, wheel chocks, etc. Besides, keeping that 15 gram card with my logbooks will keep down my flying weight.
Terry Ruprecht
