EGT Gauge Problem
Here is a question for the two or three RV drivers still flying behind steam gauges like me. My Van's EGT gauge is hooked into the #1 exhaust pipe. I usually get no reading (lower peg), sometimes I get a realistic reading and sometimes the needle wanders around aimlessly. I replaced the probe with a new one with no improvement. I have checked all connections to the gauge and made sure the Faston connections are good and tight under the cowl. I am looking for ideas what the problem might be. When I pull the probe out and heat it with a torch, I get a reading, but then nothing when I fly. Bad gauge? How to test? Thanks.
Doug
RV-9A
