  #11
Old 02-27-2013, 10:14 PM
Richard Connell Richard Connell is offline
Heres where mine lives.
FWIW Bob, I originally had mine between the seats as well, but it really didnt like sitting in direct sunlight.
I found it u/s at first annual
Hasnt dropped any weight in 2 more annuals since I moved it - and i do check it regularly now.
First thing the supplier said was"no direct sunlight". I figured it was easier to move it than remember to move it every time you leave the plane outside.
I believe that the metal valved extinguishers are far more reliable, but it was hard enough finding anyone to sell me one at all let alone exactly what I wanted.
Access obviously great for PIC, requires 2IC to loosen shoulder harness slightly.
Cheers
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 02-27-2013, 10:56 PM
912ry 912ry is offline
Default right side forward of the spar
[IMG][/IMG]
Old 02-28-2013, 04:49 AM
ao.frog ao.frog is offline
Anyone tried on top of the fuelpump-cover?
That's where I'm considering. Any good reasons not to use that position?
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 02-28-2013, 05:27 AM
Captain Avgas Captain Avgas is offline
Wherever it goes, for me the dictating factor has to be that the pilot can reach it and remove it for use in flight without having to undo or adjust his seat belt. If you have an inflight fire and you're doing a fast emergency landing, the last thing you want to be doing is messing around with your seat belt.
Placing it on the front of the spar wasn't an option for me because I have a 7A and the gear leg mount doesn't leave enough room for an extinguisher in that location.
Richards' point about not leaving the extinguisher in direct sunlight is a valid comment but I'm hopeful my Kroger sunshade will do the trick when I don't have the canopy cover on.
You’re only as good as your last landing
Bob Barrow
RV7A
Old 06-06-2013, 09:08 AM
Danger Will Robinson Danger Will Robinson is offline
The 1lb 3oz halon hand held is right between and behind the seats in my RV6 . It has since been raised about 6 inches since this pic was taken .
http://www.flickr.com/photos/lylehef...n/photostream/
If I put my right arm over the seat back It's right there.
Old 06-06-2013, 09:15 AM
DarylT's Avatar
DarylT DarylT is offline
I mounted mine on the fuel pump cover.
Daryl Tolliver
VAF 1086
Yes: I paid my =VAF= membership dues for 2020
RV-7A - N754RV: Status - Pink Slip is In! First Flight 8/23/12 - My First Flight 9/24/12!
Home from GloCustom for Paint! 3/16/13
957 hours and climbing
7th Condition Inspection complete 10/31/2019
Superior XP IO360 (180 HP), Hartzell Blended Airfoil, AF-5400 EFIS panel, Garmin Aera 660, TruTrak Vizion 385 AutoPilot, Dual Pmags
Houston, TX
Track: SPOT
Weiser Airpark (EYQ)
http://www.rv7a-factory.com
Old 06-06-2013, 11:59 AM
rzbill's Avatar
rzbill rzbill is offline
Similar positioning for mine. Link to image
However, I wanted to make a different point about the actual fire extenguisher itself. You can see the black plastic top to mine (via the image link), vs the metal top in Daryls image. GET THE METAL TOP. My plastic one pops off if I so much as LOOK at it sideways. The neck support in the bracket actually causes it to come off too. Annoying and obviously not good for quick use in emergency. POS
Bill Pendergrass
ME/AE '82
Old 06-06-2013, 02:01 PM
vfrazier's Avatar
vfrazier vfrazier is offline
For those who want something other than Halon, here is an aqueous foam, non-toxic, and non-corrosive fire extinguisher. It is available with a mounting bracket too!
Each type has advantages and disadvantages.
The good: Halon requires no clean up. Foam is cheap, can be sprayed on your body parts if needed, stays in place longer, and is arguably more effective.
The bad: Halon can suffocate you and is expensive. Foam can freeze at low temps.
YMMV!
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
