02-27-2013, 08:54 PM
Originally Posted by erikpmort
Good point. Can I add an impulse coupler or whatever you call it to my existing R mag ?
I cant say for sure but I don't think you can, I think you would need a new impulse mag and the gear and the spacer, I think they sell them in a kit. If I had to do that I would just get EI on the non impulse side.
02-27-2013, 11:00 PM
And maybe the hardest part would be replacing the studs in the case to fit the impulse mag.....
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
03-02-2013, 10:47 AM
I have a question. If I replace the right non impulse mag with a e-mag model P, what is the relationship between the electronic ignition and my existing mag ? Do I only get 50% of the EI benefits because I don't have both sides ?
So I'm stuck on a broken plane to go get my broken plane today. (Skywest) fun stuff !!
Erik Mortenson
Rans S-20 low and slow
14 build working on wings
03-02-2013, 11:21 AM
I think you get 80% of the benefit with one EI.
03-02-2013, 12:56 PM
I'm not a P-mag expert, but basically what you'll have are two ignition sources that will fire at TDC for start, both will fire at 25° BTDC at takeoff, and the P-mag will advance the timing up to some maximum (on mine it's 42° BTDC) depending on manifold pressure and RPM. So at high altitude you'll get a more efficient and more complete burn. The mag, of course will still be firing at 25° BTDC, but it adds something to the burn such that if you turned it off at high altitude you would probably notice it. I think you would get most of the benefit of having two E.I.'s, I've heard 90%, but 80% sounds reasonable too. Also, with the P-mag, it should be a fairly easy install since you won't have to change studs; you might want to convert to auto plugs for the P-mag, which will require the inserts for the plug holes. But that is strictly your choice, aviation plugs will work too, but you'll have to re-gap them.
Reason: Typos.
03-02-2013, 07:14 PM
I have an O-320, first I had two mags, then one each, then two P-Mags. With one each, I got all (as far as I can tell) of the benefits of quick starting, better idle, and saved 1 gph in fuel burn. With two P-Mags, I get perhaps a little better idle (I idle at 400 rpm and it is very smooth) and I gained 4 mph top speed, and a little higher cruise at any setting. I gained very little in fuel burn with the second P-Mag, maybe .2 gph. The first one is the biggest deal, performance wise. YMMV.
Bob
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
03-02-2013, 09:26 PM
Perfect thanks ! Got my plane home today, and even had nice tailwinds. 175 kts most of the way woo hoo. Looking forward to the upgrade. Gotta pay my darn sales tax first
Erik Mortenson
03-03-2013, 04:14 PM
What could my right side non impulse slick mag sell for ?
Erik Mortenson
03-03-2013, 04:40 PM
How much time on it? Model number? I would look up the new price and figure about 50% for a quick sale, depending on time, of course. I think the current model number would be 4370 for the non-impulse, seems like you might have an earlier model #.
Keep in mind that these are 500 hour mags and used to be called "throwaway mags." However, they can be overhauled for a couple hundred bucks.
Reason: Added last sentence.
03-03-2013, 05:09 PM
People keep saying this and it’s not accurate, these require a 500 hour inspection, they do not need to be replaced or O/H at 500 hours, I have one with about 700 hours, I replaced the points for $50 last year, otherwise it was and is in good condition and running well.
Still 50% price of new at most.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
