  #11
Old 02-25-2013, 01:18 PM
rocketbob's Avatar
The RV-6 I fly now would't start worth a **** when cold, but when it was warm it started no problem. Turned out to be reversed p-leads to the mag switch which disabled the wrong mag (the mag with an impulse coupling.)
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 02-25-2013, 01:22 PM
walkman's Avatar
walkman walkman is offline
Default Errr......
Perhaps I missed something but....
OP, do you know if you actually HAVE mags?
RV-8 IO-360 (Bought)
RV-6 O-360 C/S (Sold)
Walkman aka Flame Out
Old 02-25-2013, 01:39 PM
erikpmort's Avatar
erikpmort erikpmort is offline
Thanks guys. I wasn't working on it alone, I just wanted to have some good ideas to go from when I got started with the A&P in the morning. He told me the left mag is bad,(the one with impulse) so I'm sending it in to get overhauled. Lucky the A&P that sold me the plane offered to fix it for free minus parts. I'm sending it to him. Thanks for everyone's help.
It is a slick model 4272
Serial 90050012
Kinda makes me want to get electronic ignition.
Erik Mortenson
Rans S-20 low and slow
14 build working on wings
Old 02-25-2013, 01:47 PM
mannanj's Avatar
mannanj mannanj is offline
Check out Robert Paisley at EFII. Great electronic ignition and great to work with!
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 02-25-2013, 01:48 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Thanks guys. I wasn't working on it alone, I just wanted to have some good ideas to go from when I got started with the A&P in the morning. He told me the left mag is bad, so I'm sending it in to get overhauled. Lucky the A&P that sold me the plane offered to fix it for free minus parts. I'm sending it to him. Thanks for everyone's help.
Serial 90050012
Or you could just replace the other (non-impulse) mag with electronic ignition, especially since you'll be getting a new/overhauled impulse mag back. That way you get most of the benefits of E.I. with the least amount of capital outlay! And you'll have two sources of starting ignition.
Glad to hear your almost fixed, safe flight home.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 02-25-2013, 07:42 PM
bhester's Avatar
bhester bhester is offline
Red face
I've got one of each and I've had both fail (at different times), I like have one of each.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 02-27-2013, 12:34 PM
erikpmort's Avatar
Default results
so the Fbo diagnosed it as a bad mag. they told me its hard to find people to work on them and that i may not be able to find anyone to overhaul it. Well come to find out these guys don't know their stuff because the other 2 A&Ps i know were willing to look at it, and guess what? it ended up only needing the contact points cleaned! my local A&P said its unusual for something like that to be the problem, but he also checked the condenser and everything else looked fine.
Anyway, frusterating that the FBO there wasn't even willing to open up the mag. the guy i sent it to had it working in 15 minutes. I could have flown home the same day. Glad it wasn't worse, but gee sometimes its hard to find good help....
I like the idea of one mag and one EI. i may do that at somepoint. thanks for the advice. Now i gotta go fetch my plane 500 miles away
Erik Mortenson
Old 02-27-2013, 04:38 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
I like that idea too, but currently I have two impulse mags, both are hot at start, it you had this you would have started the engine and the dirty points would have cleared by the time you got to the run-up area and you would be home, also very handy in the back country where you need it to start and work every time, at least on one mag.
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 02-27-2013, 08:04 PM
erikpmort's Avatar
Good point. Can I add an impulse coupler or whatever you call it to my existing R mag ?
Erik Mortenson
Old 02-27-2013, 08:49 PM
Jesse's Avatar
Jesse Jesse is offline
I love dual impulse coupled mags. Starts much easier, especially on FI hot starts.
Jesse Saint
