  #11
Old 02-24-2013, 12:15 PM
Flying Scotsman Flying Scotsman is offline
Which is why I use my checklist...1000' checklist includes "Fuel Boost Pump - OFF".
I don't trust myself to remember things
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 02-24-2013, 02:29 PM
ao.frog ao.frog is offline
Default I have...
... done the same thing: wired a light so it comes on when the fuel boost pump is on.
I have installed an EXP-2 switch panel, so wiring the light was pretty easy.
I have also installed three more warning lights:
(right seat is pilot seat)
The warning lights are from right to left:
Red: low oil pressure
Amber: alternator offline
Blue: fuel boostpump is on
Green: defroster-fans are on
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 02-24-2013, 09:08 PM
Robert M's Avatar
Robert M Robert M is offline
Default Flap switch wiring with a light
Here is how my flap switch is wired. I don't suppose I can do the same thing with a light for my flap switch, can I - some how? I'm planning to use green lights. For some reason I got it my head that a red light means a bad thing.
I can't take credit for this image, I borrowed it from someone on this forum a long time ago and I can't remember who - sorry.
"Pilots: Looking down on people since 1903"
(author unknown)
RV-9, N556RM, O-320, Dual PMags, Catto 3 blade.
FLYING since 2018
Mosquito XEL ready for flight
Old 02-24-2013, 11:58 PM
Yen Yen is offline
On a slightly different tack. I have installed LEDs across the fusesfor pump etc. Those LEDs don't light up unless the fuse has blown. That will show me if a pump is inoperative even if the switch is on.
Old 02-25-2013, 10:37 AM
krw5927 krw5927 is offline
If you use an incandescent light bulb for your "flaps operating" indicator you can wire it in parallel with the flap motor just like Brantel said above. Don't even need to pay attention to polarity. It will light up any time the motor runs, in either direction. A LED indicator would make things a little more complicated, but using 2 LEDs (one for flaps going up, one for down) would be rather easy - install them both in parallel but reverse the polarity of one LED in relation to the other.
I've never seen a "flaps operating" indicator in a panel though. Can you help me understand what the utility would be?
Kurt W.
RV9A
FLYING!!!
Old 02-25-2013, 11:00 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
The circuit that Brantel put up,
only shows that the power to the pump is on. The pump could be not working, or switched to an empty tank, yet the light would show pump on.
If you are looking to have an indicator that tells when there is aux pump delivering pressure, then you need something quite different.
For normal day to day use, the above should work just fine, but you should be aware of the little gottcha I mentioned.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-25-2013, 01:19 PM
ppilotmike's Avatar
Default Tell us more...Mike.
Mike,
Your comment above has merit. The real reason we want the light on the pump is to know that it's working, not just receiving current. How would you suggest wiring something up to see that the pump is actually delivering fuel (pressure transducer or something in line?)
Mike Rettig
VAF Dues Current
Old 02-25-2013, 01:40 PM
Mike S's Avatar
Senior Curmudgeon
Well, if you have a fuel pressure gauge, you already have the info available.
If you want a warning light, a simple pressure switch in the fuel line will do it, but then you are inducing another possible leak location. Vans supplied pressure sender manifold can handle this chore.
If you really want to go custom, a DPST pressure switch could easily be rigged to show Green for pump on and pressure present, or Red for pump on no pressure.
My main purpose in the prior post was to alert folks to the fact that an indicator light "ON" doesn't necessarily mean there is pressure.
For what I would use such a light, it would be to remind me to turn off the pump after take off.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 02-25-2013, 02:34 PM
JonJay's Avatar
JonJay JonJay is offline
For what it is worth, most of the fuel pumps in our RV's are "continuous" duty rated. If you don't catch it with your checklist, catch it with your scan. If it runs for a while what's the harm? Maybe Don can chime in on his pumps?
If you do install a light for whatever purpose, have a means to check the light. Also, make sure it dims. One of the factors that led to an accident recently was a display that did not dim during a critical time of the flight
There is no free lunch. Everything added to your system is another point of failure and one more thing to manage.
You can tell I don't have a boost pump light huh?
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-25-2013, 03:31 PM
Bill_H's Avatar
Bill_H Bill_H is offline
To be really picky about it, the circuit shown only indicates that there is power to the indicator light. The branch of the wire to the pump could have a break in it.
