Old 08-01-2006, 03:43 AM
Pirkka Pirkka is offline
Default Nasty deep scratch on the skin
Just couple days a go I managed to screw up something (hopefully more is not to come ).
I did two scratches, about 2 - 3 cm long, near rivet hole to the outer side of VS skin. So, they will be eventually problem at least when place should be painted. I guess I'll just have to grind it off and then finish with SB and live with it? In case there is small displacement after that, I guess there is some stuff which can be used to fill it before painting?
PS. Had my first RV(6) flight yesterday. It really goes as faaasst... and now I know why you are so interested about the autopilots and similar.
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
Old 08-01-2006, 07:49 AM
bonanza36 bonanza36 is offline
Default Don't Worry About It.
If its only a scratch, then a little extra primer should take care of it when you paint.
John Roberts
RV7A sold
RV8 sold
Skyote Biplane 90%
