Old 02-22-2013, 04:57 AM
Bayou Bert's Avatar
Bayou Bert Bayou Bert is offline
Default IO-320 with 9.1 Pistons
What are the pros and cons of getting the 9.1-1 pistons
option from Aerosports.
I haven't had time to call them yet, but saw the option on a quote
they sent me.
Not being an A/P, I knew I could get an answer here.
Bert
Bert
RV-9A ?Pearl?
Working on Instrument ticket
Donation Done for 2020
Old 02-22-2013, 07:30 AM
Rupester Rupester is offline
Default For one ...
With 8.5:1 pistons you can run Mogas. I'm not sure about 9.1:1
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 02-22-2013, 07:55 AM
William William is offline
Default More Power
You'll pick up 4-5 hp by going with the 9:1 pistons.
RV6A flying as of November 8, 2016. N717WK
Finishing a RV10
Old 02-22-2013, 10:07 AM
terrye terrye is offline
Default Prop
You should check to see if the prop you intend to use has been tested and approved with the engine and pistons you intend to use. If it has not, I'd stick with the standard pistons.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 02-22-2013, 10:12 AM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
This slightly higher compression ratio will require the use of 100LL, but may be overall more efficient, especially with electronic ignition. Bart estimated my Aerosport IO-320-D1A with this configuration, would turn out ~170 HP. Not an actual dyno number, but his 'best guess'. In an actual side by side run with an RV-9A (O-320), I had about 1 gph favorable fuel burn advantage for the XC trip. With balanced injectors you will have a great efficiency motor with a little more power when you need it. Talk with Bart or Sue for additional details.
Just my $.02 worth...
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
Old 02-22-2013, 10:36 AM
brad walton brad walton is offline
Default Efficiency
Higher compression permits leaner operation of the engine, or operation at a lower gallons per horespower per hour.
