Old 02-21-2013, 08:31 PM
dwilson dwilson is offline
Default How thick should it be?
I am building my filter air box. I need a carb heat flapper door. The plans call for me to make one. VA-130-H.
I can't find where it says what thickness of stock to use. I am leaning towards .040, but am kind of tempted to use .062.
Anybody know "the right way" to do this?
Duane Wilson
RV9A. Built, flew 1000 hours, Sold
RV10 Built, flying 330 hours so far.
Central Oregon
Old 02-21-2013, 08:55 PM
esco esco is offline
Default Will check plans
I built that section, but I don't recall the specs (given that I manufactured the @$*#! door 4 times, I should...)
I'll check plans at the airport tomorrow and report back
______
VAF dues paid though exempt
RV-9A sold (I miss that bird!)
RV10 sold (miss that one too!)
RV-14A build underway
Old 02-22-2013, 05:52 AM
Walt's Avatar
Walt Walt is offline
I think the original might have been .032, .040 should be more than enough. I would suggest using the mil spec hinge, most of the problems are due to hinges wearing out.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
