Old 02-21-2013, 08:08 AM
bkthomps bkthomps is offline
Default Adjustable thermal switch for Avionics Fan
I've been searching for one of these, most at Mouser are defined as thermostats and are fixed range, I want to cable it up but be able to adjust the engagement point so I can control when my fans cut on- does anyone know a source for these types of switches?
Old 02-21-2013, 08:26 AM
I have one in my box-o-junk that I have been hauling around since I was 15...one day I will find a use for it...haha. I think it came from one of those cheap space heaters. You may want to check out an HVAC shop or parts website.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 02-21-2013, 08:28 AM
i have, the probably with heaters is they turn on when it is cold, i want something that turns on when it is hot. Weight/simplicity are also key factors but above all others, i want to be able to adjust engagement points
Old 02-21-2013, 08:34 AM
Probably more complex than you want:
http://www.amazon.com/Hayden-Automot...thermal+switch
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 02-21-2013, 08:35 AM
You can always just use a small relay to reverse the swiching.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 02-21-2013, 08:36 AM
PerfTech's Avatar
PerfTech PerfTech is offline
..... I purchased one that was very small, light weight, fully adjustable for temperature as well as the fan speed. I got it at one of the computer shows and it was intended for use in high end desk tops to cool the processors. You might do a search related to this and come up with something ideal. Allan...
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 02-21-2013, 08:37 AM
i have been looking on newegg, some of these look like parts of the space shuttle program, what happened to keeping things simple!
Old 02-21-2013, 08:39 AM
Here is the type of switch I have. Perfect for what you are doing assuming you are basing the switching on cabin temp rather than unit temp.
http://sell.bizrice.com/selling-lead...al-Switch.html
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 02-21-2013, 08:42 AM
that's exactly what i'm looking for, now just have to find a good supplier/source for it. simple is best and that is what this switch is
Old 02-21-2013, 05:01 PM
ecdamm ecdamm is offline
I would not recommend this for switching DC power, it's contacts are only rated for AC operation. Despite it's high AC current rating there is no corresponding DC rating. Typically contacts (switches, relays, etc.) which are rated for AC operation can only handle a tiny fraction of that in a DC load. The safe route is to find a device which is intended to switch a DC load and is rated appropriately for that load. Something with an intended application in a PC may be closer to what you're looking for.
