Old 02-18-2013, 11:52 AM
ao.frog ao.frog is offline
Default Which one of these two anti-seize products are best?
Hi.
We're ready to install the CHT-sensors, the exhaust-system and spark-plugs for the last time, and before torque'ing, I want to put on some anti-seizure compound on these components.
I have two different products in my shop, and on my first -7, I've used the anti-seizure stick on all the components mentioned above.
The stick hasn't impressed me very much however, at least not on the spark plugs.
Therefore I'm considering to try the Autolite T-556.
Does any of you have any recommendations regarding which product to use where?
Maybe Autolite on the sparkplugs and the stick on the rest? (exhaust and CHT sensors)
I have dual P-mags so I'd think that the Autolite also schould be used on the plug-adapters?
Thanks in advance for any advices.
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 02-18-2013, 12:05 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
I've used this for years with good luck:
http://www.aircraft-spruce.com/catal...clickkey=13697
A friend of mine uses this and says it works great, and is easier to carry in a plane tool kit:
http://www.napaonline.com/Catalog/Ca...828_0006382899
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 02-18-2013, 12:23 PM
JonJay's Avatar
JonJay JonJay is offline
I think it is all pretty much the same stuff.
I use the Napa paste. One little tube will last you a lifetime. I take an acid brush and cut the brissels in half. Makes a nice stiff little brush to apply it with.
It does not take much.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-18-2013, 03:27 PM
Norman CYYJ Norman CYYJ is offline
What do you do with the other half of the brush which you cut the bristles off of?
Old 02-18-2013, 03:42 PM
JonJay's Avatar
Funny. Ok, I cut the bristle part in half, err, oh never mind, I make the bristles shorter. There.
I have not found a use for the other half of the bristles yet.
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-18-2013, 03:45 PM
N15JB N15JB is offline
[quote=ao.frog;745370]Hi.
I used the Autolite T-556 for 25 years in my Pitts and 3 years in my -10. Never any problem removing the plugs in either plane.
Jim Berry
RV-10
Old 02-19-2013, 04:08 PM
Default Thanks...
... for the replies guys.
Looks like I'll try the Autolite on the sparkplugs and the stick on the rest.
