Old 02-17-2013, 01:35 PM
scsmith scsmith is offline
Default Suction cup mounts and altitude
I've recently started flying with an iFly720, and I have been using the suction-cup ram mount it came with. I was a little skeptical of the suction mount based on past experience. Yesterday was my first long flight with it, over the Sierra. At about 9000 ft, the ram mount fell off the panel.
I remember 'back in the day' in sailplane racing, before we had GPS, we used instamatic cameras mounted to the canopy rail to take pictures of turnpoints to verify that we flew the course. Some folks would try suction cup mounts on the inside of the canopy to mount a camera. Invariably at high altitude they would fall off.
At 9000 ft, the atmospheric pressure is reduced about 30%, and that is enough loss for the grip to fail with the weight I had on it.
I guess I'll have to make something more permanent.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 02-17-2013, 01:53 PM
Norman CYYJ Norman CYYJ is offline
I use suction cups to hold my sun shades on the canopy and they stay on from sea level to 18000 feet.
Old 02-17-2013, 02:59 PM
John RV8 John RV8 is offline
Default Suction cups
My Ifly700 suction cup mount would not stay in place for more than about an hour and a half even in cruise below 5500'. I finally removed the suction cup and mounted it with a bolt to an aluminum plate which can be installed/removed with one screw.
John Goodloe
RV-8. N6279G
Pay in November
Old 02-17-2013, 03:45 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
What was the air temperature?
I used to find that the suction cup that I used with a Garmin antenna would fall off when the temperature dropped to zero. I don't know if it was sublimation of water vapour or the loss of elasticity in the rubber, but it seemed to be fairly consistent regardless of actual altitude.
Old 02-18-2013, 03:34 PM
Default good point on temperature
Temperature may also be a factor. It was 31F outside. Not much cabin heat makes its way up to the panel.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
