Old 02-16-2013, 09:45 PM
skwentnaman skwentnaman is offline
Default Wiring question for ND Alternator
Hi all, this is my first post and I'm looking for a little help.
I just got the 14870 1986 samuri Alt and have a couple questions.
Will the case mount and tension arm that Vans sells work for this on my 0-320
Now for the wiring part. Currently on my plane I had an old ford alt and voltage regulator. My understanding is I can get rid of the regulator since the new alt is internal regulated. True?
Second - any one have a link to a simple way to wire in these ND style Alts. My understanding is that the main lug on Alt goes to the buss bar but I dont know where the wires go from the three prong on the back and which prongs to use
The alt has three terminals on the back, I saw the Vans 60amp alt. wiring change and they say to only use the bottom left but my alt is a Re-man and not new.
Any help would be great. Thanks
Old 02-16-2013, 10:50 PM
A follow up question - What model pulley will work?
Old 02-16-2013, 11:43 PM
gasman gasman is offline
Welcome Israel, I can't answer your question because I did not use an automotive regulator. But to speed your answer along you can search using any key word. The search button is at the top of this page. In most cases you will find answers to questions you haven't even thought of yet....
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 02-17-2013, 08:55 AM
Kent Ashton Kent Ashton is offline
Put this in Google and you will see many posts about internally regulated alternators: site:matronics.com internally regulated alternators
Also a good FAQ here discussing internally-regulated alternators
http://www.aeroelectric.com/FAQ/Aero...c-List_FAQ.pdf
It is pretty easy to modify a Denso for an external regulator See
http://www.eaa.org/experimenter/arti...alternator.asp
There are many versions of Denso with small differences in mounts. You might heat up the bracket and bend it to fit. Done that. Whatever you do, the bracket cannot put any twisting force on the Lycoming case where it bolts up. It will crack the case.
