Originally Posted by gasman
Because your limits and restrictions are linked to your N number..... they must be re-written. Usually requires a trip or two to the FISDO. It does not apply to the number that you removed. Just the one that you are installing on the experimental. And it only applies if you are changing the number. NOT to the original.
I recently sold my -8 and in the process, we also switched the n-number. The n-number went to a third party whom also happened to be a DAR. As you stated, assigning a new number to an experimental aircraft requires a new airworthiness certificate and operating limitations. Fortunately, the DAR handled that part of the paperwork dance.
However, wrt to the n-number swap, he used an aircraft title service (AIC Title Service, LLC) located in the same building as the FAA Aircraft Registration Branch to handle the paperwork. The advantage here is that the title service will hand deliver all documents directly to the FAA.
I was told that the Registration Branch will (almost) immediately process paperwork delivered by a title company, whereas, documents received by mail may take up to 10 business days before the paperwork is processed. Also, if there are any questions or snags along the way, the title service has direct contact with the FAA. I don’t know what the cost of the service was however it was very efficient.
Regards,
