The aft window should be easily removed during construction. I installed it after the skin was riveted for test fitting, removed it for painting, then reinstalled for final finish. Hope this helps.
Roberta
Aft window during fitup with skin unriveted.
Aft window all bolted in prior to paint.
Shows aft window out and fuselage finished and painted.
