The "consumption" is not affected by the air oil separator however the amount lost will decrease.
Get stuck into the thing early, keep CHT under control, and the break in will be done in 4-5 hours, or the bulk of it will be.
Dont sweat it.
But do stay above 75% if you can. And apart from the first flight, put the wheel pants and fairings on. The extra speed is cooling air flow!
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
