Old 02-13-2013, 12:39 AM
fabricflyer fabricflyer is offline
Default Best thing since pre punched skins
I finally broke down and built a rotisserie for my fuselage. Made a big difference on installing parts on the inside of the fuse. Also made painting the inside a lot easier. I recommend it for anyone.
I'm not the best welder but it turned out OK. I fabricated mine from some scrap metal, water pipe, and some old exercise equipment. Also made some arms I can use when I paint the wings. Used a universal "joint" on each end so it does not put a strain on the plane when the end poles are at different heights. Did not have to drill any addition holes to mount it to plane.Those bolts shown on the tail only go into the 2 by 4. The 2 by 4 is bolted to the F 712 bulkhead with one AN3 bolt and two AN4 bolts. Going to change up the forward end so I can attach it to motor mount after I install it.
Enclosing some pic links so you can get idea how I fabricated it.
Old 02-13-2013, 06:45 AM
bret's Avatar
bret bret is offline
Nice, I was thinking of doing this...when I get there.
Old 02-13-2013, 07:20 AM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Default Safety
When you adjust the height, do you have more than just the one "set screw" bolt holding the vertical pipe? It's hard to see if you have a pin or some redundant method to keep the support from sliding should the bolt lose its grip.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 02-13-2013, 08:51 AM
Don, I just have screw that I tighten, but you could put pins for different heights.
Old 02-13-2013, 10:55 AM
longranger's Avatar
fabricflyer,
How high are pivots off the floor? I'm thinking about adapting my (borrowed) wing stands for the fuselage.
Miles (VAF# 1238, Paid up as of 12/20)
RV-7 TU 904KM (reserved)
Construction Log
Empennage Album, Wings Album, Fuselage Album
Old 02-13-2013, 11:26 AM
Bill Phillips Bill Phillips is offline
Default On rolling the wings
I posted several years ago photos of the easy way to roll wingd for painting. Buy a long piece of 4 inch PVC pipe and suspend between two saw horses. Thread the pipe through the big rib holes. Use a 1.5 inch PVC pipe in the smaller hole as a break. Somewhere here are pics of how I did it. Cheap and worked great. Bill RV-8A Bluebird
Old 02-13-2013, 02:18 PM
Longranger, The top of my upright post are 38" high and it works well with the 7A even with the steps attached.
