Go Back   VAF Forums > Regional Forums > Southeast
Old 02-12-2013, 11:37 AM
walkman's Avatar
walkman walkman is offline
Default Snips of firewall material needed
Does anyone in the atl area have any left over snips of stainless firewall they don't need?
I have a couple of holes I no longer need and would like to patch. Need a couple of 1" or so squares.
RV-8 IO-360 (Bought)
RV-6 O-360 C/S (Sold)
Walkman aka Flame Out
Old 02-12-2013, 12:21 PM
Ironflight's Avatar
VAF Moderator / Line Boy
An alternative to patches (assuming you have some round holes you want to plug) is a pair of fender washers, a short bolt, and a nut.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 02-12-2013, 07:38 PM
Try using a stainless blank elect cover. I used one cut to fit unused brake line holes. $1.49
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 02-12-2013, 11:35 PM
bruceh's Avatar
bruceh bruceh is offline
You can also get snap in sheet metal plugs in just about any diameter from McMaster-Carr. The nose wheel bolt access hole on the RV-*A models uses one to plug the hole in the firewall. A bit of firewall sealant around it and you are sealed up tight.
Bruce Hill
2020 VAF donator
