Old 02-11-2013, 01:39 PM
chiricuca chiricuca is offline
Default Carb heat muff photos
I am installing the VANS carb heat muff in my RV-9A and practically I have no space to install the hose between the carb heat connector and the carb heat muff. Can you show me photos of your installation, please?
I know there are other carb heat muff and probably better (wicks, etc) but I'm only interested in pictures with the Vans' one.
Thank you
Old 02-11-2013, 08:24 PM
crabandy crabandy is offline
I've got the RobbinsWings muff, and the connection is close but doable. I have about two inches (maybe less) between the muff and the flange on the airbox. Could take a pic if it would help.
Old 02-12-2013, 03:04 PM
flyboy1963's Avatar
Default what's you weather like?????
Originally Posted by chiricuca View Post
I am installing the VANS carb heat muff in my RV-9A ....
Thank you
If you actually are in conditions conducive to carb ice, you really are wasting your time with the van's 'muff'. I got the Robbins' wings 6" canister, and it actually creates some heat!...unlike the Van's pretend thing, which also seemed destined to saw it's way thru my exhaust pipe.
my opinion and observations.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 02-12-2013, 03:20 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
Here is a shot of my 7A with 0-360.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 02-13-2013, 12:57 AM
Thank you for your answers
Old 02-13-2013, 05:46 AM
Walt's Avatar
Walt Walt is offline
Agree, if you actually need heat (which is not usually the case with the Lyc) the Robbins would be the preffered unit by far.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
