Old 02-10-2013, 07:29 PM
Michael Burbidge Michael Burbidge is offline
Default What did you trim baffle tops with...
I'm just about to start trimming the tops of my baffles to fit the upper cowl. There's lot's of good information about how to do this in the forums. e.g. paper clips, paint stickes, etc. But there is some detail that I've not found.
I have two questions. What did you trim the baffles with? Did you take the baffles on and off to do the trimming, or did you trim them on the engine?
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 02-10-2013, 07:34 PM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
I did it on the engine with an air nibbler. There were quite a few on/off iterations with the cowl, so it would have taken quite a while if I pulled the baffles for each trimming. I packed a towel tightly over the engine to catch metal bits, but paper/tape might be better.
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
Old 02-10-2013, 07:39 PM
Flyguytki's Avatar
Flyguytki Flyguytki is offline
Metal Shears work just fine, cut it close to the line and then finish with a file and finally sand paper.
RV-7 N87DX Built, Flown, and Sold!
Old 02-10-2013, 10:01 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Yup - hand shears are quick and easy to use with the baffles on the engine - save lots of time.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 02-10-2013, 10:21 PM
Default Shears not snips
When you say shears are you talking about something like http://www.averytools.com/prodinfo.asp?number=1451?
As opposed to snips like this http://www.averytools.com/prodinfo.asp?number=6716L?
Michael.
Michael Burbidge
Sammamish, WA
RV-14A Empennage
Old 02-10-2013, 10:57 PM
Flyguytki's Avatar
The second one, the snips. The scissors that cut aluminum
Old 02-11-2013, 01:23 PM
Captain_John's Avatar
I also used my Dremel and the abrasive wheel for the tight spots that were prone to being deformed by the snips!
CJ
The experiment works!
Old 02-11-2013, 03:14 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Snips. Then clean up with a belt sander than 3m wheel.
Al Girard, Newport, RI
N339AG
RV-9
Old 02-11-2013, 11:19 PM
Default Belt sander...
I thought I'd used every tool in my shop on my airplane. But I was wrong. I have not yet used my belt sander. I will tomorrow.
Michael
Michael Burbidge
Sammamish, WA
RV-14A Empennage
Old 02-12-2013, 06:37 AM
Michael, For the life of me, I have no idea how you could have possibly gotten this far without using your belt sander!?!
Whenever I need a long, straight edge it is the perfect tool!
I rough cut say, a baffle top and leave it proud. Bring it down to size with the belt!
On another note looking at your build log, the collective wisdom on this website (and myself included) is to not bend this ring terminal and loop the wire instead.
Stress on the ring terminal could leave you stranded at a field with a wire potentially too short to remake a connection.
BTW, it looks like you are doing AN INCREDIBLY GREAT JOB!!!
Keep it up!
CJ
