Old 02-10-2013, 06:43 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Default Clarification of Alternator Slip Torque Tension
I've got the Slip Torque tension guide from Plane Power on how to tension the alternator belt (http://www.plane-power.com/images/AL...TENSIONING.pdf). It specifies to use a torque wrench on alternator pulley-retaining nut. I pull the alternator down the adjustment bracket, tighten the adjustment arm and then use the torque wrench, but I'm not 100% sure of what I am supposed to be looking for. It says the slip torque for a new belt is 11-13 Ft Lbs.
So if I have the alternator at the right tension, then when I move the torque wrench, I am assuming the belt should have enough tension it moves the flywheel. But should it continue to move the belt even if I hold the prop in place up to 11-13 ft lbs?
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 02-10-2013, 07:10 PM
JonJay's Avatar
JonJay JonJay is offline
That is correct. It should slip in that range. If it doesn't, the belt is too tight.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-10-2013, 09:49 PM
tim2542 tim2542 is offline
Yeah I think you want to hold the engine still during the test, the belt should not slip below the 11-13. At least that's what I have been doing.
Tim
Old 02-11-2013, 04:36 AM
Kevin Horton's Avatar
The numbers are from Lycoming SI 1129A Accessory Drive Belt Tension.
With a new belt, the belt must not slip when you apply 11 ft-lb torque. The belt must slip when you apply 13 ft-lb torque. If it passes both those tests you are done. If it fails, adjust the tension and try again.
If you have a used belt, the correct range is 7 - 9 ft-lb.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
