Originally Posted by gasman
These springs won't change the issue of lose cables.
And the tightness of the pedal to master issue, is just a matter of proper adjustment of the fasteners. These springs look like they will work just fine. But there is no problem with the springs and collar over the shaft.... It has nothing to do with scaring the piston IN the cylinder.
Gasman is correct - This is not a fix for loose rudder cables. If you don't like the loose rudder cables you can buy Aerosport Products' rudder trim. It works great and as a by-product it keeps the rudder cables tight. That also keeps the rudder from banging around in a light wind. I have one and love it.
I spoke to George at Matco, who supplies Vans with the master cylinders. He said it was a great fix because he didn't like builders putting springs over the pistons. He is the person who told me it would scar. I guess if you buy the right parts, where the spring won't rub on the piston in the compressed state, it will work. He is sending builders my way who ask. As I stated earlier, not everyone has the problem. My pedals were loose from the individual bolts and still not returning the pedal. I tried the spring on the actuator and didn't like the setup.
Rockwood, I was just in KEGE a few days ago for work. Probably the same time you were in KSLC. I will have to make a trip out there. Pretty area!
