Go Back   VAF Forums > Model Specific > RV-3
Old 02-10-2013, 03:52 PM
Tony Spicer Tony Spicer is offline
Default How to make an RV-3 cowl look really sharp!
It's easy. Just do this. Wish I had known about it when I built my -3.
Tony
Old 02-10-2013, 07:56 PM
KatieB's Avatar
KatieB KatieB is offline
Too bad your cowling is the only thing that wasn't broken...
Katie Bosman
EAA Homebuilt Aircraft Council
Rebuilt most of SNF tornado victim RV-3B Tony Boy II (had to sell him, but he's flying!)
VAF Dues Paid 2021!
Thoughts & opinions expressed here are my own, and not those of my employer.
Old 02-10-2013, 09:02 PM
hydroguy2's Avatar
Very nice Tony. Gives us an update as you move along. I have to do a RV-4 canopy skirt in a couple months and this will be perfect way.
Old 02-10-2013, 09:22 PM
Brian,
If you're going to do a frame and skirt, check this out.
Tony
Old 02-10-2013, 10:52 PM
hydroguy2's Avatar
Thanks Tony. I'm helping a friend finish his -4. The canopy skirt is about 1/2 done, but looks a little rough. Plus the canopy has a 2" crack on the aft edge. So we probably be replacing the whole thing and starting over.
Old 02-11-2013, 10:02 AM
Originally Posted by Tony Spicer View Post
Brian,
Tony
Tony,
Thanks.... do you have any updated links to the rest of the RV-3 construction?
Dave
RV-3B abuilding
Old 02-11-2013, 04:26 PM
Dave,
Didn't do a real good job of documenting, but here's what I have:
https://picasaweb.google.com/tonyboy...XHwNL-__v2nQE#
https://picasaweb.google.com/tonyboy...Ja_9J2GuKagfg#
https://picasaweb.google.com/tonyboy...Kma1fKMkpj8Vw#
Tony
Old 02-12-2013, 08:25 AM
lukej's Avatar
lukej lukej is offline
Looking good Tony,,
Old 02-12-2013, 08:57 AM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
Looks good! The one thing to consider for future projects would be to cut at least some of the fiberglass strips on the bias at about 45 degrees to the width of the roll. The bias strips will drape a lot more easily around curves and creases like the one across the front edge of the canopy.
It is good that you are trying to protect your airways and lungs from epoxy fumes; most epoxies have at least some sensitizing volatiles that can eventually lead to allergic reactions. However, those paper nuisance masks will do almost nothing to protect you. At my shop we always use NIOSH activated charcoal respirators intended to protect from organic solvents.
Thanks, Bob K.
Bob Kuykendall
Low-drag wingtips for RV-4 through RV-8
EAA Technical Counselor
Old 02-12-2013, 10:32 AM
Thanks, Tony!
Dave
