View Poll Results: How did you primer the inside of your wing skins?
No priming of interior wing skin surface 18 19.78%
Primed entire interior wing skin surface 55 60.44%
Primed only rivet lines inside wing skin 15 16.48%
Other: Explain 3 3.30%
Voters: 91. You may not vote on this poll
Old 02-10-2013, 01:03 PM
Gregg Brightwell's Avatar
Gregg Brightwell Gregg Brightwell is offline
Arrow *Priming Inside Wing Skins*
Hi all,
I know that this should likely be put it the primer section, but I needed the increased visibility of the general forum, as I am to the point to decide...
I have never created a poll before, but trying to on this one.
I am trying to make the options as follows:
1. No priming at all on interior wing skin surface
2. Primered the entire interior wing skin surface
3. Primered rivet lines only inside skin
4. Other: explain
Many thanks,
Gregg
Gregg J. Brightwell
Benton, KS
CFII/MEII, ATP, AGI, A&P
-4 Emp and Wings complete!
Fuselage out of the jig!
www.mykitlog.com/gbrightwell
Old 02-10-2013, 02:03 PM
Dave Bernard's Avatar
Dave Bernard Dave Bernard is offline
Good poll, thanks Gregg.
I'm almost to that stage- was planning on just priming the rivet lines and spar flanges. I'm in a dry climate and just priming with one-step self-etching primer so far.
I didn't select anything on the poll since I haven't done that step yet...
Db
"Almost Done"
CAF Stearman pilot
Old 02-10-2013, 02:13 PM
mark schoening's Avatar
mark schoening mark schoening is offline
just finished annual on cherokee 180. dropped tanks (1968 -44 yr old plane) inside wing alum still perfect, shines and no corrosion. flex fuel lines- All alum still very good--decided to not prime my rv-9. If around salt spray or keep plane outside, or floats--prime.
RV-9 -- 0-320 -- 993RV--
Old 02-10-2013, 02:17 PM
Jerry Fischer's Avatar
Jerry Fischer Jerry Fischer is offline
Default priming
prime all... forget about problems later
Jerry Fischer KW4F
VAF# 1646
USS Randolph CVS-15 V-6 Div. AT2
RV7 N364SJ Miss Sandy sold
RV1 N1583 "Mockingbird 1" SOLD
EAA volunteer SNF
HBC volunteer/co-chairman OSH
Tech counselor
Old 02-10-2013, 06:53 PM
airguy's Avatar
airguy airguy is offline
I primed all of my interior surfaces, but it was mostly because I didn't know what I didn't know - I was afraid of the dark.
After doing a LOT of research since then, I would not do it again on my next airplane (and I will almost certainly offend again). Every builder must make this decision on their own and for their own reasons.
One point of note - given the general fear of corrosion in the rest of the world, having a fully-primed airplane will probably increase your sales price.
Old 02-10-2013, 07:07 PM
David Z David Z is offline
On the tail, I just did the rivet lines, all the mating surfaces. In the wings I'm doing everything. My friend is an airframe structural tech, so he's full of horror stories and that probably influenced my decision. Also, for the effort going into doing mating surfaces, might as well just do it all.
You have to look at the flying your going to do too. Always in a hangar, fly on "severe VFR" days only, then your probably okay. Flying in rain, snow/slush covered runways, near salt-water then you are higher risk.
RV-8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage is "in the mail"
83126
Dash 8 day job is financing the RV-8
Donation till September 2021
Old 02-10-2013, 07:17 PM
Av8torTom's Avatar
Default Very light coat
I primed the ribs and all mating surfaces thoroughly, then sprayed a light coat on the wing skins.
N677AT reserved
Superior XP O-320, 160HP
Old 02-10-2013, 07:26 PM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
Tom, do you have a jeweler's loupe or some sort of magnifier you could use to inspect the light spray job? I find myself somewhat skeptical. I'm assuming a spray job that looks light or thin might actually just be partial coverage. If the area of the skin that has light coverage is really 40% primer, and 60% bare aluminum, is that really helpful when it comes to protecting from corrosion?
If my skepticism is unwarranted, someone please set me straight.
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
Old 02-10-2013, 08:32 PM
GAHco's Avatar
GAHco GAHco is offline
Default Almost all
I primed the structure and the inside skins & where any skin laps on another.
All Azco Noble green zinc chromate process. It all came out beautifully!
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 02-10-2013, 09:06 PM
DaleB's Avatar
DaleB DaleB is offline
I bought mine partially assembled. The empennage was already together and everything is primed. The top skins for the left wing and the left leading edge were already primed over the entire inner surface. In the interest of balance and consistency, I'll prime the LE and top skins of the right wing also. But, after that I am thinking I'll probably only prime the rivet lines.
Then again... it does look nice, and wouldn't add but a couple of pounds to the weight of the plane. So put me down for "Undecided". Like you, I assume.
Dale
Omaha, NE
Previous RV-7 project (sold)
