Old 02-09-2013, 03:38 PM
Skybolt Al's Avatar
Skybolt Al Skybolt Al is offline
Default How do I measure the flap angle?
This might be a dumb question but I'm trying to get 40 deg flap travel on my 9A but I'm not sure if I measure from the top of the flap or the bottom. Putting my protractor on top, I get 40 deg, but if I put the protractor on the bottom of the flap, I only get 30 deg.
Thanks.
Al
RV-9A
Allen@AllenRice.net
Started 7/09
First flight 7/8/2015
Love this plane!!
Old 02-09-2013, 04:27 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Pick the top OR the bottom and measure in the same place when the flap is full up and full down.
Also, I don't think you're supposed to be seeing 40 degrees. I think if you look in the manual it says something around 32 degrees of travel is what is standard max for the RV-9.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 02-09-2013, 04:30 PM
gstone gstone is offline
Default I believe....
If you measure the angle with them retracted and then deployed the difference between the two should equal the forty degrees. Measuring top or bottom will not matter as long as same on both....
Yep! What he said !
Old 02-09-2013, 05:00 PM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
Only 32-37* on the 9/9A. See Section 15 page2...,,
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
Old 02-09-2013, 05:48 PM
Brantel's Avatar
Brantel Brantel is offline
The free level app on an Iphone works great for this. Raise the flaps all the way, set the Iphone to zero and then lower the flaps and read the angle on the screen.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 02-10-2013, 09:43 PM
Skybolt Al's Avatar
Default I don't know why
I never thought to measure the difference between retracted and extended.
Thanks everyone.
Al
RV-9A
Allen@AllenRice.net
Started 7/09
Love this plane!!
Old 02-11-2013, 07:52 AM
DaleB's Avatar
DaleB DaleB is offline
There's an equally useful protractor app for Android. Set the phone/tablet on the surface, hit the button to set zero, move the flap (or in my case the elevator) and read it directly. Cool as heck.
Dale
Omaha, NE
Previous RV-7 project (sold)
