Old 02-09-2013, 08:58 AM
Steve Ashby's Avatar
Steve Ashby Steve Ashby is offline
Default West System Fast Hardner OK?
My buddy John Morgan flew me down to Peachtree City, GA this week so that I could replenish my resin and hardner supply at ACS. when I got home, I realized I purchased the fast hardner instead of the slow hardner I have been using. Will that be workable, or should I go back and swap it out for the slow? I am just about finished with the canopy skirt and I will have to do the wheel pants, intersection fairings and wing tips later.
Steve Ashby
Stone Mountain, GA
N184RW (reserved)
RV-8A
YIO-360 180 hp Lycoming
Hartzell Blended Airfoil Prop
Engine Hung
Old 02-09-2013, 09:10 AM
Pat Stewart Pat Stewart is offline
I used the fast hardener most of the time with no problem, especially in the winter.
Old 02-09-2013, 09:34 AM
AJ85WA's Avatar
AJ85WA AJ85WA is offline
Default I prefer it
I have started with the slow , and now using the fast. I would buy the fast one again.
AJ Wessels (Perth Australia)
Completed - RV6
http://rv6aj.wordpress.com/
Old 02-09-2013, 09:59 AM
jjconstant's Avatar
jjconstant jjconstant is offline
The only time I use slow is when it's very hot in the hangar (100F) and I want a pot life of longer than 5 minutes
All Best
Jeremy Constant
RV7A "Stella Luna" ECI IO-360 WW200RV Pmags 360hrs
VAF 2019 paid plus some for those who can't
Old 02-09-2013, 11:29 AM
rv6rick's Avatar
rv6rick rv6rick is offline
JOAT-MON & Moderator
Hi Steve,
I have yet to work on a project that required the 'fast' hardner. I use the 'slow' hardner exclusively and have used this on many many airplane (and other) projects. This gives me plenty of working time regardless of the ambient temperature. If I get a phone call or other distraction I'm never concerned about my epoxy. I have used the fast hardner in the past.....this is why I only use the slow.
In short there is absolutely no reason that the fast hardner will not work for you....just set up your task so it will be done in accordance of the working time for you hardner. If you are doing a bigger job like a windscreen lay up then just mix smaller amounts.
Have fun Steve!
Rick Gray in Ohio - Builder Assist Center - 50+ Awards & counting
BRONZE / SILVER & GOLD LINDY AWARD WINNING RV's & Rockets
EAA Oshkosh Homebuilt Judge/Tech Counselor/Flight Advisor / F.A.S.T. Formation Flight Lead
Kitfox/RV4/6/7/8/9/10/12/14?s
6 RV10's
2 Time Sun n Fun Grand Champion
F1 Rocket #1 Oshkosh Gold Lindy Grand Champion!
F1 Rocket #2 :-)
Fastback RV8 Slider
RV14 #2 in progress
53 RV's & Rockets & counting
Whirlwind Prop Dealer
Love my Pitts S-1S
Old 02-09-2013, 07:35 PM
flyingriki's Avatar
flyingriki flyingriki is offline
It's always best to go to the correct source of information for product data:
http://www.westsystem.com/ss/hardener-selection-guide/
They know the chemistry and what is best in terms of temperature and cure times. All else is just hearsay.....
Old 02-09-2013, 07:56 PM
I use both - depending on what I am doing. If I am filling pinholes or covering tape, I use the fast. Same with setting anything I need to clamp. If I am laying up several layers, I use the slow. I can't imagine using slow smoothing the inside of the cowl or even the outside pinholes. Just don't mix up more than you can use. What is great with West systems - and probably the others is you get a choice.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 02-10-2013, 02:02 PM
Rupester Rupester is offline
Default I use both ...
Similar to Rockwood, I use fast hardener on small jobs and most flox applications; while using the slow stuff on larger jobs that will take more time. I like 'em both; can't imagine not having the choice on each task/project.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 02-10-2013, 02:19 PM
Jerry Fischer's Avatar
Jerry Fischer Jerry Fischer is offline
Default hardner
Steve I used both, fast really works OK in our colder wx right now
Jerry Fischer KW4F
VAF# 1646
USS Randolph CVS-15 V-6 Div. AT2
RV7 N364SJ Miss Sandy sold
RV1 N1583 "Mockingbird 1" SOLD
EAA volunteer SNF
HBC volunteer/co-chairman OSH
Tech counselor
Old 02-11-2013, 05:44 AM
Default Thank you for all of the info guys!
This is just what I needed. I will use the fast hardner, but will probably pick up some slow hardner when I get to the windshield layout (which requires more time). You guys are the best!
Steve Ashby
Stone Mountain, GA
N184RW (reserved)
RV-8A
Engine Hung
