Old 02-07-2013, 11:31 PM
zyskowski zyskowski is offline
Default Wing Fuse Attack - skins?
I'm ready to attach the wings for the first time on my RV7, and have not yet completed rivet installation on bottom wing skins. Does anyone believe this is a significant issue? My main concern is potential of alignment change at final install.
Z
Old 02-08-2013, 06:10 AM
Walt's Avatar
Walt Walt is offline
Sounds to me like you are not ready to install the wings if the wing skins are not riveted on yet. The wing structure can twist if the skins are not installed.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 02-08-2013, 12:01 PM
airguy's Avatar
airguy airguy is offline
Yes, you'll definitely need all the wing skins riveted on before mounting the wings. The wing skins carry a good deal of structural load and need to be in place.
Old 02-08-2013, 12:58 PM
rocketbob's Avatar
If this is a QB wing, with the top and LE skins riveted on, you will be fine. In fact I think its a good idea because it allows you to dimple the holes drilled for the fuselage skin overhang, instead of countersinking them. In older kits (-3,-4,-6) if there is a problem with the rear spar stub, its a lot easier to correct if the bottom skins and wing walk ribs aren't riveted.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
