Old 02-06-2013, 02:34 PM
bpattonsoa bpattonsoa is offline
Default Which vent for Aerosport overhead and Panel
Need to be thinking about putting in the overhead. Having a wonderful time doing the cabin sils for the McMaster Carr seal. Going to look and work great, but it sure is a lot of sanding dust!
What do people recommend for the overhead? Looks like Stein has two good vents, which is the best, or is there something else out there?
Also, I don't like the way Vans does the front vents, will incorporate them into the panel like in my -6A. I have the good Vans vents for my -6, what are there other good choices? Looks like at least 1 AMU no matter where I go.
Bruce Patton
Rans S-20 Raven 796S flying since 2019 (slowly)
RV-6A 596S flying since '99 (Sold)
HP-18 5596S flying since '89
RV-10 996S flying since 2014, quick build wing and slow build fues., - dual Skyviews with complete system, two radio and not much else. Interior completely finished with Zolatone. CF plenum. 1624 lbs, FLYING after a 21.5 month build.
Old 02-06-2013, 04:05 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
I used the stein vents. They seal very tightly, but not inexpensive.
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 02-06-2013, 04:22 PM
Aerosport1's Avatar
Aerosport1 Aerosport1 is offline
Use the Stein small vents.
Geoff
Geoff Combs
RV-10 N829GW 865hrs
1940 Piper J3 Cub
Rans S21
Old 02-06-2013, 11:23 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
I used the Aveo vents as they were a little less expensive than the Stein Air ones, just as well made and a little easier to install as the nut is easier to grab.
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 02-07-2013, 08:02 AM
douglassmt douglassmt is offline
Default +1 for Stein
I have 6 of the Stein vents. They seal very well, not cheap, but very sturdy. I found I needed a little threadlock on the locking ring to keep it from loosening. Get the Aerosport Naca Valve controller too. The OH console will leak air if you don't have it. Not the Stein vents, just little leaks here and there at penetrations and the access panels. Bugs the heck out of my wife so I put in the vent controller. I swear she could make a career as an air leak detector.
Bryan Douglass
=VAF= 2020 dues paid
RV-10 N242BD
Old 02-15-2013, 05:53 AM
AMac AMac is offline
I got the Aveo, a friend got the Stein. If I'd seen the Stein before I bought Aveo, I'd buy the Stein.
Old 02-15-2013, 08:51 AM
I got the smaller Stein. Very nice!
I don't see how you could make a better vent.
Bruce Patton
