Old 02-05-2013, 12:02 PM
walkman's Avatar
walkman walkman is offline
Default Wire annunciator light when B&C OVM trips
I'm deciding what annunciator lights to include on my panel.
GRT EIS / HXr handles most through the EIS "master alarm" light.
I'd like a few extras. One I'm considering would illuminate when either of the B&C over voltage modules trips.
Does anyone have a wiring diagram for this?
cheers!
RV-8 IO-360 (Bought)
RV-6 O-360 C/S (Sold)
Walkman aka Flame Out
Old 02-05-2013, 12:51 PM
bcondrey bcondrey is offline
Not really necessary - when it trips it will take the alternator offline and you'll get an under voltage alarm from the EFIS. The exact level is user programmable but usually just above battery only voltage and below alternator voltage.
Sorry, doesn't answer your question but something else to consider. Also, most people use the EFIS alarming rather than the EIS. More parameters and it puts everything in one place. You'll get yellow or red messages right on the PFD and a button to acknowledge them.
Bob
Old 02-05-2013, 08:21 PM
walkman's Avatar
well, I may not get a low voltage depending on
1) where I set the low voltage level and
2) if the OVM for my standby goes, or the the standby field breaker trips for some other reason (e.g. short) but the primary has not failed.
Old 02-06-2013, 06:16 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Try this one.
http://www.pflanzer-aviation.com/Rocket/PDF%20Files/Alternator.pdf
Randy Pflanzer
Greenwood, IN
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 02-06-2013, 08:36 AM
airguy's Avatar
airguy airguy is offline
My standby SD8 comes with its own crowbar, fail-light and relay, but a ship-overvoltage condition will trip both the main and standby OVM circuits they way they are wired. That will alert you via the EFIS alarms on dropping voltage, and you'll have to reset the alternators individually to troubleshoot which one is sick. That's do-able, but cumbersome in the heat of the moment. I plan on having ammeter shunts on both alternators so I can see which one is feeding current, and how much, in real time. Information is power.
