Go Back   VAF Forums > Main > Reviews
Old 02-04-2013, 07:28 PM
AX-O's Avatar
AX-O AX-O is offline
Thumbs up DJM tail wheel feedback
Just wanted to give you guys some feedback on the DJM tail wheel. I have been doing my conditional inspection for the last two weeks. During the inspection I found that the tail wheel had some play (side to side). The bearings looked ok but I did notice that the inner spacers had signs of wear
I decided to install a DJM tail wheel. I contacted Dayton Murdock on VAF and a few days later the tail wheel showed up. The swap was very simple. I used washers as spacers and had it installed in about 5 minutes. I did not think it would make much of a difference but I was wrong.
-As soon as I pushed the plane out of the hangar I noticed that the plane was quiet. I ran over the door rails and it did not sound like the plane was going to fall apart.
-As I started to taxied, I notice that a muffled “tud” sound was heard versus the old “bang” as I taxied over cracks.
-As I continue to taxi, the ground handling felt smooth, solid and crisp. Same way during take offs and landings.
I was really surprised that something as simple and small as a tail wheel would have such a noticeable impact on the aircraft. As I put my plane away I noticed that I was very happy with the flight experience. Then I told myself that I needed to write some feedback so others could potentially give it a try.
Attached are some pics of before and after. BTW, if you saw the video of the tail wheel assemble testing, that is the same tail wheel. If it can handle that abuse without any failure, I think it can handle my paved runway without any problems.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weigh out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk. Further more, these are my opinions and not those of my employer.
Old 02-04-2013, 09:24 PM
N941WR's Avatar
N941WR N941WR is offline
Good timing Axel. I just took this picture on Friday (I too am doing my condition inspection.) and called Dayton with the numbers.
It has 201.5 hours and 354 lands, most of which were on pavement.
In all that time, it has only lost 1/8" in diameter. It is hard to tell in the picture but it is 5-3/8" in diameter, down from 5-1/2" when new.
With its sealed bearings, all I did was clean it and put it back on.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-05-2013, 08:46 AM
db8's Avatar
db8 db8 is offline
Default DJM Tailwheel Review
I too have the DJM tail wheel and think the world of it (and Dayton). It is a very smooth and quiet tail wheel. I like how it "grips" the payment. I have had it on my plane from day 1, and would recommend it without hesitation.
Dave Buntin
http://i55.tinypic.com/iny6qa.jpg RV-8, N 130YS, BOYS & TOYS
[size="1"][color="Blue"]
Old 02-05-2013, 10:18 AM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default DJM
I have had "one" of the first Wheels from Dayton. I have not measured it or kept up with the times or landings,,,, but it has given me good service, shows no wear, and gets a lot of landings,
It has made me more popular, better looking, faster, and improved my memory. I think I will keep it!
Good going Dayton!!
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
Old 02-05-2013, 11:05 PM
Subwaybob's Avatar
Subwaybob Subwaybob is offline
Can they glue two of them together? I need two of em...
Bob
RV-10 QB Here 8-25-19
RV-7
My brain shows a remarkable capacity to not willingly accept information that it considered useless.
Old 02-06-2013, 10:11 AM
JonJay's Avatar
JonJay JonJay is offline
Smile
Good going Dayton!!
That is funny!
Actually, it's not just the tailwheel. When you hang around Dayton you actually do get better looking! (sorry Dayton, couldn't resist.)
Food for thought; Dayton lives near Dayton Valley. Paul and Louise are moving to Dayton Valley. I am not sure what is going on but I am determined to put the pieces together with this whole Dayton thing.
PS - Dayon's tailwheel is excellent. I only ran it a short time as it was a bit too light for me c.g. wise. If you need weight off the back, or just a really good tailwheel, his is a great product.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 11-08-2018, 10:09 AM
Jimd Jimd is offline
Default Contact info?
Does anyone have contact info for the DJM tailwheel?
Jim
RV-6
RV-10 tail kit 50%
(When do I get to measure something?)
"Flying north of the Arctic Circle and back - several thousand dollars,
Doing it in an RV you built yourself - PRICELESS!"
Old 11-08-2018, 10:26 AM
MarkW's Avatar
MarkW MarkW is offline
I think Flyboy Accessories is your best bet.
http://www.flyboyaccessories.com/Lig...ire-p/1002.htm
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 11-08-2018, 10:34 AM
Mark,
Thanks, I have already talked with them and I need some detail about the tire and wheel that I didn't get.
Jim
RV-6
RV-10 tail kit 50%
Old 11-08-2018, 11:11 AM
chrispratt's Avatar
chrispratt chrispratt is offline
Super Moderator
Default Plus 1
+1 for this wheel/tire. I've had one for a couple of years now and it is so much better than the standard wheel/tire that comes with the kits. Much softer ride, less noise, less vibration. It's worth the price.
Chris Pratt (2021 VAF DUES PAID)
RV-8 Flying, 850+hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Northwest Regional, TX)
