Bob's mods and flight testing have been very interesting to follow. Thanks for sharing all the details here with us.
Inlet control has not been popular probably for 2 reasons:
As we restrict the inlet area with a fixed exit, velocity at the exit decreases which is not desireable.
Building a variable geometry inlet which does not cause serious airflow separation in typical cheek type inlet cowlings is difficult due to the short distances involved and transition to the plenum.
We must think of the duct inlets and outlets as the pumps for the system, both are equally important for the lowest possible losses.
I've run some CFA plots on the 6A at different Alphas and the pressure distribution at the inlets does not change appreciably.
Plume drag is mainly evident when there is leakage between a high and low pressure zone at obtuse angles to the relative airflow. A non- gap sealed aileron or flap is a good example where high pressure air from the wing bottom seeks the low pressure area on top, funneling through the gaps to exit on top . The high velocity plume coming through the gap causes drag by forming a wall of air nearly perpendicular to the relative airflow.
Air cooled engines present a big problem packaging a proper duct for efficient airflow due to all the other things in the way like exhaust pipes, engine mounts etc. Ideally we'd like to encase the entire engine in a sealed duct with round inlets feeding a smoothly transitioning plenum on top and a similar plenum on the bottom of the engine to smoothly turn the airflow aft and out the exits. This is hard to do with all the junk in the way and all the junk causes drag just as if it was on the outside of the aircraft. The duct needs to be treated as an internal aerodynamic structure for lowest drag.
Of historical interest is the use of streamlined tubing on the Westland Whirlwind to form a open spar truss for the cooling air to pass through to the wing root mounted radiators for lower drag. The same idea could be applied to an RV with lightweight teardrop shaped fairings being applied to any round tubes in the cooling airstream.
On most planes, we rely on the cowling bottom to turn the air and focus it out the belly exit. It works ok, it is simple, light and makes the engine easy to work on. A sealed duct... well you see the compromises.
If we could make a nice duct on our race plane, it would be beneficial as well to change the exit duct shape and length, encorporate our cowl flap and use wasted exhaust energy to pump cooling air through our duct. Unfortunately on an existing design like the RV, this is difficult to do again properly. DG's Reno winning Lancair uses the exhaust pipes submerged in the exit duct to pull air through the system, heat it, expand it and accelerate it to good effect.
While we might not be able to do all of this, we should be able to make improvements on the existing design.
Now Bob, what will you be trying next?
