Old 02-02-2013, 07:28 AM
pilot28906 pilot28906 is offline
Default Saw Horse Height?
Hello all. Just starting the part where I need the saw horses on the RV7 fuselage. What height horse is best? I am 5'8" if that matters.
John Johnson
Murphy, NC
RV7
Old 02-02-2013, 09:26 AM
rv7charlie rv7charlie is offline
I just used what I had available. I'm 5-9+, & sometimes I was sitting, sometimes standing on a step stool of some sort, etc, as work position dictated. I suppose that doesn't help you much...
Old 02-07-2013, 10:25 PM
FresnoR's Avatar
FresnoR FresnoR is offline
I used the create your own sawhorse brackets from Home Depot, where you use 2x4's. They worked out pretty well because I could reduce the height of them as the fuselage build grew larger.
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
Old 02-08-2013, 12:00 PM
XOverZero's Avatar
XOverZero XOverZero is offline
Default Variable
Different phases of the project may favor different working heights, adjusted for your stature and comfort. I decided to spring for a pair of height adjustable sawhorses made by Stanley, and so far am glad to have spent the little bit extra on them. IIRC they run about $60/pair from either Lowes or HD, and maybe others. They adjust from 30" to 37". Ref post no. 534 on the following page...
http://www.vansairforce.com/communit...=29232&page=54
The only down side is that they have to be unloaded and folded flat to change the height, but so far that has not been a problem for me.
John Halcrow
Tustin, CA
RV-12 120682
Emp/TC done; Wings done; Fuse kit done
"History teaches us that men and nations behave wisely once they have exhausted all other alternatives." --Abba Eban
Paid up until Aug 2021
Old 02-08-2013, 01:04 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Saw horses
John. I bought the same horses some time ago.
Use them for my bench which works very well.
It breaks down in minutes. Works well for various
Construction projects as well. I use them at the min.
Height.
http://www.vansairforce.com/communit...ad.php?t=66543
Al Girard, Newport, RI
N339AG
RV-9
Old 02-08-2013, 03:52 PM
Thanks all. Last weekend i purchased the brackets that use 2x4's as i had a lot of them from the wing stands. They are 36" now and are fine but will probably need to be shortened down the road.
John Johnson
Murphy, NC
RV7
Old 02-08-2013, 09:08 PM
Taildrgr's Avatar
Taildrgr Taildrgr is offline
I originally built my fuse stand based on some plans posted on this site. Once I got my quick build, I found I had to cut a lot off to lower the stand to a good height for me. I am also 5' 8" and my stand is 14" under the spar and 22" under the tail. It is on wheels that allows me to move the fuse around the garage as needed.
Bob B
RV-7A Sold
RV-4 Sold
DFW TX
Dues Paid
