Old 02-01-2013, 08:47 PM
blueflyer's Avatar
blueflyer blueflyer is offline
Default Will this work?
Look in the upper left corner of the diagram (where the arrow is pointing). I have put an ANL 60 after the master relay and then tie in the 6 awg wire to the 4awg wire. Will this work as drawn? Any thoughts or comments?
Old 02-01-2013, 08:58 PM
All the starter current would flow thru the ANL60. I don't think it can handle that.
Old 02-02-2013, 02:57 AM
Since you have an ANL60 on the output of your alternator, if you want to also have an ANL60 from the output of your battery, it would go along in line with that segment you scribbled out.
Placing your ANL60 inline to the starter will fail since the starter takes high current.
Old 02-02-2013, 05:58 AM
blueflyer's Avatar
yep, your're both correrct of course. I didn't think that through enough before posting.....
Old 02-02-2013, 08:41 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
The above comments about starter current are correct, but you can take care of that pretty easy.
What is the goal here, it looks like you are trying to protect the main buss??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-02-2013, 08:56 AM
Norman CYYJ Norman CYYJ is offline
Not large enough for the starter current required.
Old 02-02-2013, 03:46 PM
blueflyer's Avatar
I was looking at putting my battery in the back and wanting to protect that big 4 awg wire that will always be hot. I just didnt think through what I was doing before I posted.
I did some research and I have decided that i will run it without fuse protection, making sure it is properly routed and kept away from any chance of a short.
From searching on this site, I believe the 10 has this hot wire running through the cockpit without any fuse protection also.
Old 02-02-2013, 03:56 PM
Mike S's Avatar
Senior Curmudgeon
You are correct that the 10 has no protection for the main power wire from the batt to the firewall mounted starter relay.
It does however have the main contactor mounted by the battery, so the wire is only hot when the master is "on".
Mike Starkey
VAF 909
Rv-10, N210LM.
