Old 02-01-2013, 09:29 AM
mattsmith mattsmith is offline
Default battery fuse
I am finishing the electrical and wiring on my 8A (finally) and have a concern about the #2 cable running from the battery to the starter solenoid being unprotected. I chose the rear mounting position for the battery and have a PC 680 and am wondering what the rite amperage fuse ratting would be to protect the #2 cable from the battery. I will be cranking an IO 360 with a Sky Tech 149LS. Anyone have a fuse on the battery to protect this wire?
This is the fuse I am thinking of using.
http://www.goodboatgear.com/detail/1...FdSLPAodOjkAyw
Matt Smith
RV 8A
IO-360 A1A
65 Hrs
dual skiview
Reno, NV
Old 02-01-2013, 06:25 PM
chaskuss chaskuss is offline
Matt,
Check out the thread linked below.
http://www.vansairforce.com/communit...t=battery+fuse
Charlie
Old 02-01-2013, 06:37 PM
cfiidon's Avatar
cfiidon cfiidon is offline
Default My free opinion, worth every penny
Matt,
Generally in our aircraft we don't fuse the starter feed as it is a "momentary" circuit (See Aeroelectric Connection). Number 2 cable has a rating of 181 amps, and AC 43 recommends a 100 amp fuse for #2 in a bundle (not the case for a starter feed). I doubt 100 amps is big enough.
You can protect the circuit if you want, but in my opinion it's not necessary. I doubt any battery starter combination can draw enough power long enough to melt the #2 wire, and the other scenario would be a worn through shorted #2 cable to ground. How long will you hold that starter button in when nothing is happening?
But anything could happen. You could have a starter contactor fused and continually supplying power to the starter feed that is shorted to ground ... until it acts like a fuse itself... or you reach over and turn the master off.
Having said all that, build it the way that makes you happy. You can probably make the terminal mounts and fuse size work for you. Carry a spare.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
